************************ Original post
Hello,
MB newbie here just getting started on my first build. Found a Briggs & Stratton 3.5hp motor for $30, and a '79 Chicago Schwinn bike for $60. My goal is to build something reliable, heavy-duty, fast, and cool looking. Meaning, flat bars bobber style.
Motor mount is cut from some .187" steel plate. Plate is not yet welded in the photo.
The frame seemed a bit small, so I hacksawed through the chainstays between the BB and the kickstand mount (to keep the strength) and proceeded to straighten out the seatstays and bend the chainstays with a C-clamp and a couple of strong beams. On Friday, made a part from some stainless tubing to connect the chainstays.. and dropped everything at the welder's.
The plan is to have a tensioned belt jackshaft setup with clutch lever, disc brake on the front, possibly a multi-speed rear internal gear hub.. or even a such hub mounted externally.. under the jackshaft.. so that I can swap it out quickly in case it breaks down
Or even... a locked up 5-gear freewheel on the back with a heavy duty derailleur spring? It would drag sure... but it would be like driving a manual transmission almost...
The stretch is going to force my BB much lower to the ground. Anybody know of any wide cranksets with short crank arms?
And what to do about mounting that cruiser seat?? ahhh decisions... decisions...
