I'm talking about the ten t sprocket on the motor. If I take off the nut and washer, There should be a bearing visible right ? Is that bearin the enclosed type or is it the open type where I could put some grease on the ball bearings. This motor is noisie and I'm thinking they pressed the bearing into to tight of a hole. A bearing should have .0005 press fit but I think the hole was smaller when pressed in. Appreciate any help.
