azbill's EZM stretch project
azbill
3,358
Fountain Hills, Arizona
John,
I can't wait to get this on the road and see how she pulls,,,a ride/meeting you will be really cool :)
Civilzed,
I have ONLY been able to pedal so far ;),,,the small pedal sprocket seems to be very easy going :), slow but very easy pedalling:)
ps...I think the 72T is the biggest Jim has made... so far (very pleased with his work)
azbill
3,358
Barron,
I am hoping to need no tensioners on engine side
(if my 1eyed measurements are correct LOL)
I may need 1 on top run to clear the crossbar that the fender bolts to
(I have always heard not to run on top with the 2strokes, I hope it will be ok with my EZM :))
I am getting good karma from some of the builders here I respect the most...thanks a lot guys (^)
RedB66
1,020
14
Sunshine State
I've mounted them on the top. Not as tensioners but, more as guides. If you do go with one on the top...it will need to really secure. The height of that sprocket is going to want to pull the chain up.
azbill
3,358
someone asked me if I was worried about the wheel/bike bearings (they don't have a good rep)
I am not using the original wheels, so that's not an issue...
all the upgraded parts I have gotten over the years for the Jag are going on the stretch, with the exception of the black springer (won't fit, the stretch has a much longer stearing-tube :()
the headset and crank bearings were replaced with better ones and packed in high-temp bearing grease from Ace
I already have my bent crank from the Jag on it (using kiddie crank on Jag till the swap)
Vinnie has started on the tank (his 1st, and using aluminum) and I am hoping to be riding soon :)
azbill
3,358
azVinnie finished my tank ( his first scratch-built) (^)
all aluminum, tigged and ground smooth :)
suits the lines so nicely, holds about 1 gal :)
pic 1 left profile (some flames just buffed as a test)
pic 2 straddling rear wheel
pic 3 right profile showing cap n drain
pic 4 close-up of right side
pic 5 cut-out in front of tank so springer clears lock-to-lock
I am going to rough up the surface and use black primer, then black satin engine paint :)
thanks again Vinnie, you rock dude !!! (^)
Retmachinist
635
22
Urbandale Ia
Wow, Sweet Tank Bill. I can see Vinnie has quite a bit of experience with the Tig welder. Anyone can use a Mig, but Tig takes alot of practice, I am impressed. Does Vinnie do Tig welding at his job?
It will be nice, I will actually be able to see your bike in the desert in late March. I will call you when we are there. Can't wait to get to where it is warm!
John
azbill
3,358
Vinnie did all the design, shaped the pieces, ground the welds, and made the petcock on a lathe...
the tig work was done by a friend where Vin works :) nice to have friends ;)
2door
Moderator
Staff member
16,302
175
Littleton, Colorado
I can't wait to see this one finished. I've just been lurking and watching cause I know that bike is in good hands. Keep us informed, Bill.
civlized
689
Alabama
Let me wipe the drool from my face. That looks great! That sprocket is HUGE, looks awesome. And the tank, the tank. Does that dude want to build some more? That is gonna be sweet, Bill.
azbill
3,358
Vinnie is my son-in-law...I live with him n my daughter :)
I have been dreamin of/planning a stretch for 3+ yrs
I love it when a plan (finally) come together laff
thanks for the props guys !!! :)
azbill
3,358
just 1 more set of pics before I primer/paint :)
1st pic detail of the bottm of tank (Vinnie turned 2 chunks of aluminum into the fuel outlet, and a 1/4-20 tapped hole that will be cross clamped to the canti-bars)
2nd pic showing the bung welding (bought the cap n bung)
3rd pic showing notch out to clear forks
4th pic right profile
civlized
689
Alabama
There is no way I would paint that tank. Little polish and some clear coat, maybe. I'm sure it will still look great, though.
azbill
3,358
almost done :)...
exhaust needs to be lengthened so muffler is under and parallel to frame,
couple of tensioners/chain guides to clear frame, (temporary zip-tie in pics)
fenders, and I think that's all (^)
lights will be done at a later time
hope you like it :)
Retmachinist
635
22
Urbandale Ia
almost done :)...
couple of tensioners/chain guides to clear frame, (temporary zip-ties in pics)
hope you like it :)
Very nice Bill. You should have plenty of low end with that sprocket. Can't wait to see it in person, when we are in FH the third week of March.
John
