Instead of the usual digital tachometers that I have seen many of on the forums here and around the internet, I was looking to find if there's any way to mount an analogue tach on our HT powered bikes because I don't like the look of the tiny tachs, and the refresh rate of the display itself is not quite ideal.
So I scoured the internet for a short while yesterday and after looking at MANY tachs, found this one : My apologies,... due to some mild level of retardation, I'm unable to post links (even though I am a registered member) But here's the (broken) address :
www. iequus. com/Product/Detail/7988C0B8-0121-429D-99D7-7B0DD14DBE08
The Equus 6068 is a black 2.5 inch 0-8000 RPM tach that works with 1 ~ 12 cylinders, and either 2 or 4 stroke. It also features 3 different methods of getting a RPM signal. Method 1 : direct ignition tach signal (no chance there), Option 2 : Inductive pick-up on ignition wire (maybe) or Option 3 : Inductive pick-up on spark plug wire (most likely).
Option 3 sounds like it would work to me (Although with only one wire that comes from the ignition, it's virtually the same as option 2). In fact, the most difficult part would be securing a 12v battery source and then mounting the tach to the bike.
Anyone know if this would work? Or if it's been done already?
BARRY
BARRY
