I bought this Kent bike for the frame, because it was inexpensive and I was going to upgrade a lot of the components anyway. I wanted it for the aluminum and not the full suspension. Popular opinion on the forum is the aluminum frames can't take the vibration associated withe Chinese engines. Then I've been reading airplanes are made from the same material in many instances and they vibrate a lot. I guess time will tell and steel frames break apart also. I gathered all the tweaks I could find on the forum (thanks guys) and applied them to this engine. Match ported and polished the intake and exhaust, removed the base cylinder gasket, lapped the head, changed the plug wire, plug, notched the piston where it blocked the intake port, lapped the cylinder. added SHA Dellorto, added tuned pipe, changed the hubs and rims (local bike shop did this part). The front hub brake is no better for short distance stopping in my opinion than the original v-brake. It may hold better over long distance stopping. I don't know. It was on sale and I thought it was cool so that is why it is on this bike. I've had it on another bike also. On the crank side of the shifter kit I changed to an 8 tooth sprocket. My other bikes bogged down in the higher gears and the power develops in the higher rpms with these engines I think. This engine runs and idles better than any other I've owned. It has more torque than I've ever had. It just keeps on winding. I rode this morning to find the top end mph. It was cold as !@#$%^&* little above 30 degrees. A couple of my neighbors blew the horn as they went past me. This was to make sure I know they see how crazy I am. Before my speedometer quit, froze probably, I recorded 39.4 for a top speed. I was pleased with this under the cold conditions. It may do a little better when it warms up and I can "tweak" it a little more.
