79cc Sportsman Flyer build
PeteMcP
918
2,545
93
68
Ludwig,
Not sure if it's the same but MEK (Methyl Ethyl Ketone) is commonly sold as the go to brand of liquid adhesive used for assembling plastic model kits. I used this for years till I discovered cellulose (lacquer) thinners does the same job just as well and can be purchased in half gallon cans from hardware stores for about the same cost as a small container of MEK from a hobby shop. The odour from either is the same and sufficient to make anyone - unless glue sniffing is your thing - realize that breathing it in, other than sparingly, is not a good idea.
Tom from Rubicon
2,793
6,026
Rubicon, Wisconsin
One of the prettiest girls I ever knew irepairably damaged herself sniffing solvents.
She could have cleaned my Solar acetylene lamp and inhaled fumes too, kinda multitasking :D.
I'm getting dizzy from the fuming or is fulminating?
In the mean time I have to order some #35 Diamond chain.
Tom from Rubicon
2,793
6,026
Rubicon, Wisconsin
Home from hospital having diner date with Sweetie we had Palestinian Shwarma, Falafel, salad, and the best hummus I ever ate.
Arriving home the mail box had my #35 Diamond chain so I will make a new chain for the primary drive, and a lot of good it will do me now with is crazy record breaking cold wintery weather.
I am still kicking around sending AGK my other 79cc engine for the full mod performance package.
https://affordablegokarts.com/colle...roducts/modified-79cc-predator-engine-stage-2
indian22
4,725
7,711
Oklahoma
Winters the time to get that motor work done Tom. I'd think even a mild rework would free up 3+ hp & still be easy to live with. Once valves are controlled the revs are there to work with , while float is pushed past the point of any found horsepower. All these industrial motors are under cammed profile little lift or duration.
Rick C.
MotoMagz
1,817
1,154
Michigan
Get the parts and do it yourself ? Agk sells most everything.It is easy and was my last winter project. Never did it before and it was very easy with directions. Could save yourself a lot of coin. Could get more inhalants! Or a 212!
Tom from Rubicon
2,793
6,026
Rubicon, Wisconsin
Waiting to see what we have left after Medicare and supplemental.
As Moto says, just getting parts and letting AGK do what they do best is the ideal method. It is on my mind daily.
Guess it is time to clear the bench (No small task as things have been piling up since I converted a 1868 Vetterli to centerfire ). That was five years ago and the Flyer just compounded the bench load.
Tom from Rubicon
2,793
6,026
Rubicon, Wisconsin
Venice Motor Bikes
Mar 20, 2008
7,274
1,812
Los Angeles, CA.
Tom from Rubicon
2,793
6,026
Rubicon, Wisconsin
Took Mona for a Sunday ride and found a little Burg I had not found in our 14 years living in this locale Kohlsville, WI
https://www.google.com/maps/place/K...0xa6564ec4f9fe1d83!8m2!3d43.47111!4d-88.32194
A cross roads mill town back in the day, some other noodling around to find our way home.
Mona happy, me go to shop. Pulled the side cover off the crankcase to remove the governor guts. Gasket did not survive. Plan B, what is best gasket thickness?
Varies .020" to .012", not a lot but. Thoughts?
