what bikes have ya'll used for a 4-stroke in frame mount? I'm using the Honda GX-50, and unfortunately it doesn't fit the bike I had planned to slip it into. carburetor wants to insert itself into the seatpost.... which obviously won't work.
What gearbox are you using with that shift kit?what bikes have ya'll used for a 4-stroke in frame mount? I'm using the Honda GX-50, and unfortunately it doesn't fit the bike I had planned to slip it into. carburetor wants to insert itself into the seatpost.... which obviously won't work.
thanks for your help.. i did speak with jim from sbp he said the same thing here is a picture of what i have the cranks are super wide and the spindle is really long i still have 1-2 inch clearance and its lower than the 4g tranny they came with the kit i bought off helio bikes http://i1201.photobucket.com/albums/bb350/locutus_34/S7302079.jpgHi locutus, it is true that the HS+HS 4G is much wider than the HS/Honda + Honda 4G. About 1.5", and that extra width is on the gearbox side, where clearance is very tight. I have HS + Honda 4G and my pedals are within 1/8" on the gearbox side, 1/16" if I put the 4G cover on.
HS+HS 4G on a SBP kit can be done tho. There are a couple methods:
1) You'll need to have crank arms with more of an offset than the ones that the SBP kit comes with. Your main objective would be to get the left crank arm to clear the 4G.
2) Get shorter crank arms. If your left crank arm doesn't intrude into the 4G's space, then you don't have a crank clearance problem. All you'd have to worry about is your pant legs. 4G without covers love pant legs lol You can get pedal extenders to take care of that.
3) Get a wider spindle than what SBP offers. SBP's widest bottom bracket spindle is 203mm. If you can get one that has an extra 35-40mm on the left side, you won't have a clearance problem. However, the largest drawback of wide crank spindles is that they reduce pedal torque and are more susceptible to getting bent. Pedaling doesn't matter to most the MaBers here, but it matters to me, and it may matter to you.
Hope this helps!
