Well Ive been working on another fuelmizer project. I took a 150cc scooter and made a vapor carb? out of a mason jar.
I got the idea from a few videos I found on youtube. All the ones I saw had issue with proper fuel/air ratios. As did mine for a couple of attempts.
My first attempt got great milage a huge increase in power and rpms, it also burnt a hole thru the piston in 19 miles. So I installed a new piston a set of rings and honed the cylinder.
For my 2nd attempt I restricted the airflow using a smaller intake tube to richen the mix I made it 28.8 miles and yup another hole in another piston as well as tearing up the cylinder wall. so a new piston, jug and rings got installed.
So for my 3rd try I wised up and got a little air/fuel mixture guage that goes between the plug and jug. Restricted the air flow even more,raised the fuel level in the jar. but that was still not enough. Then I tried 87 octane fuel instead of 93 as well as a colder plug. This looked good after a 100 miles or so we took the head off and there was some damage to the piston. So I was moving in the right direction. I replaced the piston but used the rings over again.
Attempt #4 I decided to use E-85 and raise the fuel level. I retarded the ignition at this point as well. After 100 miles I took the head back off, there was no damage to the piston.
This leaves the only 2 problems 1st) that the air/fuel mixture is only right @ a certain level in the jar. only 3 oz. of safe usable fuel level out of a 16 oz. jar. 2nd) Refilling the jar every 9 miles so I don't burn a hole in the piston.
What Im looking to build is a duel cavity carb, one for the fuel to be turned to vapor and one that'll have a float, needle and seat for a constant metered flow and level of fuel. The problem comes from the need for the 2 cavities to be connected (to maintain constant level) both cavities want to vaporize. This keeps my float needle in an open position continuing to fill both cavities.
Anyone got any educated ideas?????
Thanks, Rick
Thanks, Rick
