Well.. I decided to see what my Titans with shifter kits could really handle. I took 2 Titan IFFM setups up past Fairplay Colorado. These two Titan IFFM are slightly different. I am running the DAX shifter kit with 1/2 drive. 44T main, 28T secondary, 8T on the gear box. I am around 6 feet tall and 175lbs. My son is running an SG setup with 36T Main #35 or 8mm, with 22T secondary and 11T Gear box. Now.. Keep in mind.. I can pull a trailer with 75 lbs of gear around town with no problems at all. But.. That is 6000 feet or so.. and on hard surfaces. Now..I am up above FairPlay.. And I would like to get above Timber line. Timberline is around 12,000 feet or so.. So.... We lit our bikes.. And off we went.. Climbing to about 11,000 feet where we hit snow falling off and on. I could see timberline and where I want to be.. My bike is dragging on the clutch on the really steep parts and I can tell after about 1/2 hour of climbing that I just do not have the gearing low enough for this kind of riding. I do not want to burn my clutch up and It was getting colder and more snow by the minute.. So.. We turned around and bombed all the way back to the cabin. It was a blast going back down.. But.. The climb.. Not so fun.. I can tell I need much lower gearing as my goal is to take a Motor Assisted Bicycle higher than anyone in the world !! I want to be the first man in History to bike a Motor Assisted Bicycle to over 14,000 feet !! I will take some pictures to show everyone. I ordered some different sprockets and that should do the trick . Since my power was down so much at those high altitudes, I will need some really low gearing. I may have to lean my carb a little also.. But..The main problem is gearing.. I hope to try again next week. This is no easy feat to be sure. Wish me luck !! And.. Enjoy the ride...
