07-29-2009, 08:52 PM
What Do These Chinese Symbols Mean?
Where do I put the lever between these two Chinese symbols and does anyone know what the one on the top means and the one on the bottom means?
Thanks
07-29-2009, 09:17 PM
Re: What Do These Chinese Symbols Mean?
That is your choke, lever up is closed, lever down is open. With you motor warmed up the lever should be down. If the motor does not die with the lever up then you may have an air leak.
My buddy could never get his motor to start without using the choke, I never needed to use the choke to start mine.
07-29-2009, 09:37 PM
Top = on, lower = off. Or at least that is the way the choke lever works. Nunya is correct. Choke closed it up and open is down. The Chinese 2 strokes warm up reasonably fast. About 30/45 seconds and your engine should run normally with the choke wide open in moderate weather. The colder it is the longer you'll need some choke, lever up...but not all the way.
What's the matter; you can't read Chinese?
07-29-2009, 09:41 PM
So I want it all the way up?
07-29-2009, 09:44 PM
Only to get the engine started..................after it starts open (lever down) the choke.
07-29-2009, 09:50 PM
So start it with it up and when I get going for 30-45 seconds push it down? I've just been leaving it in one position and trying out different positions and leaving it there, not moving it once I get going.
07-29-2009, 10:12 PM
Another thing to do is temporarily remove the air cleaner, then you can see that bad boy in action.
07-29-2009, 10:16 PM
But wait til I go through the breakthrough period for that right? I initially had my throttle put together wrong and my bike was only going really fast, so I sorta already got an idea what it can do.
07-29-2009, 10:20 PM
No I didn't mean performance of the bike as a whole, I meant you could see how the choke works with the air cleaner off.
07-30-2009, 06:08 PM
LOL, I thought they were Chinese symbols too! They're really just pictograms- in the top one a tube (air intake) is being sealed off, and on the bottom one it is open.
| Thread Tools |
| Display Modes |
Linear Mode
