Old 07-28-2009, 06:07 PM
xXRCLGXx xXRCLGXx is offline
Banned
Default Centrifugal Clutch add-on kit
are they better than the clutch that comes in the motor
Old 07-28-2009, 08:30 PM
Ilikeabikea's Avatar
Ilikeabikea Ilikeabikea is online now
Default Re: Centrifugal Clutch add-on kit
With a centrifugal clutch you have to have a pull starter. You can't pedal start............
Old 07-28-2009, 08:51 PM
Cabinfever1977's Avatar
heres what it said about my dualstart dualclutch engine:
Dual GGG model; Allows pedal starting as well as rope pull engine start. Uses a friction clutch as well as a special centrifugal clutch with over running clutch lock up to pedal start; Handle Bar Clutch lever must be in the engaged position to operate in centrifugal clutch drive mode. In disengaged lever position the engine is in free wheel mode separated from drive line. Note: A standard friction clutch engine can not be converted to GGG dual mode due to different crankshaft
Old 07-28-2009, 11:18 PM
donuts31 donuts31 is offline
you can pedal start with a centrifugal clutch kit, at least I do on two of my bikes that have one.
Old 07-29-2009, 07:05 PM
POPS's Avatar
POPS POPS is offline
Hi Cabin
I do not know what Dual GGG means but You can buy the pull start and C/F clutch
from Zoombicycles but they will only fit on the 69cc motor. From what I read they will not fit on the
49cc. I bought 2 kits and they were real easy to install...POPS
Old 07-30-2009, 02:27 PM
my 48cc engine came with a pullstart and centrifugel clutch already.
Old 03-17-2011, 12:09 PM
rohmell's Avatar
rohmell rohmell is offline
I bought a centrifugal clutch kit from ZoomCycles.
The clutch has a one-way sprag-type of system inside of it.
The engine can be started by pedaling and releasing the hand clutch just as before. Once started, the motor can idle at a stop without use of the hand clutch.
Old 03-17-2011, 12:21 PM
Hammond Egger Hammond Egger is offline
GGG means Give Gas Go.
Old 10-19-2011, 12:55 PM
rohmell's Avatar
It also means grubby Grubee garbage.
Old 10-20-2011, 02:13 PM
Dan's Avatar
Dan Dan is offline
Sounds purty cool Rohmell. Do you have any links?
I want 2 ride my bicycle
