Old 05-13-2008, 06:06 PM
molock molock is offline
Default I need help!!!!!!!
My bike now runs very well with help of this site and some friends but I cant get the rear hub to stay put it wants to open up when I ride and gets louse after only a mile or so on the right side how can I fix this issue? chi I.L.
Old 05-13-2008, 06:13 PM
Bikeguy Joe's Avatar
Default Re: I need help!!!!!!!
You mean the axel /cones get loose? Make sure your locknut is there and nothing is rubbing to loosen the axel.
Is this a coaster brake or cassette?
Old 05-13-2008, 09:34 PM
sisdavid sisdavid is offline
mine did that a lot then it kind of stopped. Get one of those bicycle wrenches that are flat hold the lock nut with it and turn the big one. Get them tight together.
Old 05-13-2008, 09:55 PM
Easy Rider's Avatar
Easy Rider Easy Rider is offline
Santa Cruz Scooter Works
My coaster brake hub does it alot also.
Old 05-14-2008, 06:20 AM
Unless there is crud or sand or ??? in there to really speed up the wear, nothing should loosen up if everything is tight and adjusted properly from the start. It is a bit tricky to get it right the first time sometimes and I know with a coaster brake you have to remove or grind down the dust cover one the engine sprocket side to clear the sprocket.
Better very slightly loose than too tight.
