Old 06-24-2009, 10:02 PM
aliston aliston is offline
Default New... Confused... Frustrated
Hello I bought a used motorized bike...test rode it was great. I ran out of gas and put more in I believe it was 40:1. It ran for a little while than it just died. I replaced spark plug, but still nothing. Any help would be appreciated.
Old 06-24-2009, 11:41 PM
Finfan's Avatar
Finfan Finfan is offline
Default Re: New... Confused... Frustrated
We will probably need a few more details than that for a diagnosis. If you can get the rear wheel off the ground try removing the spark plug. Then while hand turning the wheel hold the metal side of the plug against the engine and see if you have a spark. That would be a simple first test anyway. An engine needs three things to run. Air, fuel, and spark. So start studying and eliminating possibilities until you find it. Good luck.
-and-
I'm not lost, I'm exploring!
Old 06-25-2009, 12:02 AM
Cabinfever1977's Avatar
i hope its really good oil at 40:1
Old 06-25-2009, 12:29 AM
MelMartinez's Avatar
MelMartinez MelMartinez is offline
Dealer in Mexico
A good mix is 20:1. Itīs safe and wonīt make smoke.
Old 06-25-2009, 01:23 AM
Emerica's Avatar
Emerica Emerica is offline
Unless you are using Amsoil or other oils designed to run at such ratios.
Old 06-25-2009, 08:04 AM
Bikeguy Joe's Avatar
20:1 is too rich no matter what oil you use.
Check for spark.
Check for fuel flow to the carb.
Remove the carb if both of those check out, and look for debris in the float bowl and jet.
Old 06-25-2009, 10:39 PM
My magneto is producing a current but there is no spark when plug is held touching the engine. Can the CDI go bad?
Old 06-25-2009, 11:09 PM
Emerica's Avatar
They can but make sure that the plug wire is making a connection to the cdi before trashing it for a new one. I think its just a philips screw that makes a connection in there.
Old 06-26-2009, 01:01 AM
skyliner skyliner is offline
40:1 is 2.6 oz per gal you want to run 25:1 witch is 5oz per gal good luck maybe you could tell us more
if you dont see smoke your doin somthing wrong fly low beat the radar
04 shcwinn 80cc dax sbp camber cns carb boost bottle k&n filter 36 tooth 40mph (gps tested) havin fun and smokin scooters
Old 06-26-2009, 10:17 AM
Is there away to tell if the CDI works w/o having to move the pedals?
Does the Green wire need to be hooked up?
