Old 05-27-2009, 01:31 PM
Cabinfever1977's Avatar
Lightbulb cdi alternative?
i was on the other engine bike website the other day and saw that someone had replaced there cdi with a yamaha yz 80 cdi(78 model with 2 wires) and it worked for them.
im not saying to go and use one since are regular stock cdi's are only like $10 or so.
but that guy was having problems with all his stock cdis and he found that one at a local store and it worked better for his engine on his bike.i dont think he paid much for it either since he bought it used.
its possible that it could be used as a alternative cdi,maybe if someone tested it out.
Old 05-27-2009, 01:48 PM
Pablo's Avatar
Pablo Pablo is offline
Default Re: cdi alternative?
He said he paid $5 for his. I can't seem to find them for less than $50. So good luck with that.
Old 05-27-2009, 01:51 PM
$50,well maybe only if you really need one while youre waiting in the mail for a replacement stock one,but you could probally get a stock cdi from fedex or ups in a couples of days,but with shipping it would be close to $50
im guess im lucky my stock cdi still works.
Old 05-27-2009, 01:55 PM
Pablo's Avatar
I'm just hoping there is a lower cost source for the YZ-80 so I can try it.
Old 05-27-2009, 07:27 PM
i found some lower price cdi's online but there not the 2-wire ones.
i dont think motorcycle parts are good replacements for our bike engine parts because there high prices,unless you have some lying around.
Old 05-27-2009, 10:49 PM
matt167 matt167 is offline
remember, you get what you pay for.. our CDI's are $10 but the spark ignition is probably not accurate when it comes to spark timing... with a motorcycle or dirt bike box, you will gain the ability for a real tachometer ( not the tiny tach with a 5yr non replacable battery and 2.5s response ) if you choose, as well as higher energy spark ( run wider plug gaps= jetted richer and more power )..
if your really looking for cheap, eliminate the CDI and run the plug wire off the mag just as your weed eater or chainsaw does
Old 05-28-2009, 01:58 AM
Goat Herder's Avatar
Gutter Rider
I just checked my plug gap I was at 40 thousands with a Direct hit From pulstar its was running just fine! Did not have my gapper handy when I put it in I was eyeballing for 30 thou....
Old 05-28-2009, 09:23 AM
doesn't mean it is a good consistant spark... 2 strokes will run with any kind of ignition, doesn't always mean it will run it's best... somthing that sells for $10 will never be as good as somthing that sells for $50.. you just can't expect it to
Old 05-28-2009, 11:13 AM
Gutter Rider
Heres my link I just bought two more of them . No I am not confused with it. Yes it works........ http://motorbicycling.com/f13/direct...-any-7257.html
Old 05-28-2009, 05:45 PM
I'v seen those... general consensus in the automotive world, is they don't gain anything ( dyno testing ), but on a 2 stroke who knows.. possible an old resistor plug could do the same gain tho
of course, average voltage on a car that would test on those plugs is 10-40k volts, and a little CDI may do 10k volts on a good day.. so there are some diffrences
BTW, the CDI is a coil... the magneto creates a 'pulse' and it induces energy in the secondary windings of the CDI, making spark voltage.. the spark is not directly magneto driven
