Motorized Bicycle Trouble ShootingUse this area to post problems that may arise that you could use some help in figuring out what is wrong with their bicycle motor and what needs to be done to achieve top performance.
Its your float bowl. In the carb the bowl has a float that works a needle valve shut when bowl is full. There could be debrees thrash in the fuel line, or the float needs adjusting.The filters in the tanks on these are notorious for clogging or falling apart . A in line fuel filter is recommended. This link might shed some light on the subject! http://motorbicycling.com/f30/motori...build-302.html
