03-03-2009, 01:09 PM
tensioner pulley
Quick question: where can one purchase a tensioner pulley or its components?
03-03-2009, 01:31 PM
Re: tensioner pulley
What type are you looking for, just the standard one that comes with the kit?
John
03-03-2009, 01:39 PM
nothing fancy...just whatever is going to get me back on the road asap
03-03-2009, 01:46 PM
03-03-2009, 01:47 PM
If all you need is the little pulley, alot of people use a skateboard wheel which is very easy to find. They come with roller bearings that have an 8 MM diameter. Should be what you need. They are better than the standard kit pulley. I usually turn my own out of Delrin.
John
03-03-2009, 01:49 PM
If you are really in a rush you could make one up or if possible just shorten the chain. Some bikes work out well without the thing.
You could also order one; Page Title
03-03-2009, 02:28 PM
I want to do the skateboard wheel thing, but I dont have access to a lathe to carve into it. Could I get away without doing that or perhaps is there another method?
03-03-2009, 02:38 PM
You could put your drill in a vise or use a drill press for a poor man's lathe... I've done it, not pretty but pretty effective.
I have not actually done it this way but I've read here where some guys have chucked the skateboard wheel into a drill and used a file to cut the chain groove. A drill press would work better and be safer than a hand drill. You'll need some way to keep the wheel from spinning on whatever you use through it. When I cut wheels on a lathe I remove the bearings and run a bolt through the bearing bore and tighten it. Then I chuck the bolt into the lathe. Something to keep in mind is that there are 2 different styles of skateboard wheel. The better ones are one piece ureathane and the less desirable ones have a solid inner core with a rubberized outer jacket. The 2 part ones don't lend themselves to being cut into because the outer skin comes off and leaves you with a hard core that isn't much better than the kit tensioner wheel. Good luck.
03-03-2009, 03:14 PM
Here's my "method".
I put the bolt through the skate wheel, "drive" the wheel with a bench grinder, and cut it with a hacksaw blade.....dangerous and exciting, but effective.
| Thread Tools |
| Display Modes |
Linear Mode
