Old 02-25-2009, 08:25 PM
...ladies's Avatar
...ladies ...ladies is offline
Default Exhaust Gasket Replacement?
One of the sides of my exhaust did not have the lock washer on it for some reason and came loose and blew the gasket. It now spits the hot oil on my leg at WOT. Anybody know where i can get just a replacement gasket material or make one? Have access to a CNC if thats at all a help.
-Nick
"Those who conform, lose all ideas"
Old 02-25-2009, 08:46 PM
Banned
Default Re: Exhaust Gasket Replacement?
Copper sheet .045-.060 thick...heat it with a propane torch to a dead-soft condition, Cherry red...EDIT, (easily pliable by hand). Make your gasket. Torque the header...run the engine up to normal temp...re-torque the header...DONE!
Jim
Old 02-25-2009, 09:04 PM
mechanickid's Avatar
mechanickid mechanickid is offline
wow thats a pretty extreme way to make the smoke go down the pipe! if it were up to me i would stick any old thing in there. the tough cardboard on the back of note pads is an easy and sure way to go. tacky, but hey, i fix stuff with a sledgehammer. if it works it works.
its only too fast if you cant stay on!
Old 02-25-2009, 09:23 PM
Banned
LOL...A few minutes with a punch kit, and a tin snip...I really wanted to make a Die & Punch set so that the gasket would be formed perfectly. I hear Ya'...a Heavy paper gasket will work fine too, as long as no whistlers get through. A small leak will burn through paper quick!
Jim
Old 02-25-2009, 09:27 PM
sorry btw, i meant no disrespect.
true.
i actually dont have a gasket on mine right now. i just too darn excited to hear it run right again. :P
Old 02-26-2009, 09:45 AM
NunyaBidness's Avatar
NunyaBidness NunyaBidness is offline
I have had to replce the exhaust gasket several times. I also used the cardboard from the back of an old notebook. I wiped it down real good with 2 stroke oil and have not had one blow or leak on me yet. I just manage to tear them when I pull the muffler off causing me to have to make a new one.
This trick works good for those of us that don't have a well stocked shop.
Old 02-26-2009, 10:03 AM
jasonh's Avatar
jasonh jasonh is offline
I used the gasket material from the auto parts store...just the standard, not the heavy duty or anything. It blew pretty quick. High-temp RTV on both sides of the cardboard gasket will keep it from blowing. I ran probably 700mi with the gasket like that.
Old 02-26-2009, 11:17 AM
oldcliff oldcliff is offline
I used some hi-temp gasket material that came from an auto store. I've had the stuff for years. Use to use it for tractor manifolds. It's gray and is about the same thickness as the back of a notebook cardboard. It is very stiff and needs to be cut with an utility knife.
Hope this helps
Old 03-08-2009, 05:21 AM
saolom saolom is offline
I use $2 dollar store superglue and glue seal the edges. Then i use a very thin layer of RTV Silicone red stuff . Have not changed it for 6months so work excellent!
Old 03-08-2009, 07:38 AM
oylavabeer oylavabeer is offline
Mine blew 10 km from home, I just cleaned the surfaces back to bear metat and siliconed in place have traveled 200km since no probs thanks for the reminder to retorque the nuts
