Old 07-08-2016, 05:54 PM
motor bike project motor bike project is offline
Unhappy Motor bike project
Hello, I was wondering how I could attach a sprocket to a weed eater, and then direct chain drive to gears on my bike. How would I attach the sprocket to the weed eater?
Thanks
Old 07-08-2016, 08:08 PM
crassius's Avatar
crassius crassius is offline
Default Re: Motor bike project
you'll need to read a lot - did you have some type of clutch in mind?
Sometimes I sets and thinks, sometimes I jes sets.
Old 07-09-2016, 07:03 AM
Agreen's Avatar
Agreen Agreen is offline
The simple answer is that it's not easy to do. Pretty much (and I'm trying to say this in as nice a way possible) if you need to ask, you probably don't have the equipment and capabilities.
However, look up friction drives. You essentially bolt on a roller to the weedeater and make that run in reverse on the rear tire. Boom. Motorized bike.
Never stop wrenching
Old 07-09-2016, 07:28 AM
I am thinking now that a friction drive would be easier, but how would you attach the peg to the weed wacker? Or could I use a socket? The weed wacker is a Troy Bilt TB575 SS.
Old 07-10-2016, 06:31 PM
sbest's Avatar
sbest sbest is offline
A weed eater is totally wrong for a bicycle.
Bolt a prop on and use it to power a canoe!
You may have to experiment with prop pitch and diameter.
Go fine pitch and moderate diameter is a suggestion.
Steve
That's a mighty noisy bike you got there, it must haul a lot of ass?
Old 07-11-2016, 08:50 PM
Mike Stroz Mike Stroz is offline
Try a chainsaw instead, it already has a chain drive!
Old 07-13-2016, 03:27 AM
Tony01's Avatar
Tony01 Tony01 is offline
I'd get some 4 stroke kit and put the weedeater on the front of the bike, believe me nobody will cut you off
I don't always listen to Alice in Chains..... but when I do, SO DO THE NEIGHBORS
MxTrq clutch tuning | 212cc 2spd | CVT tuning
Tags
bike, sprocket installation, wacker, weed eater
MotorBicycling.com
