Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Motorized Bicycle Welding, Fabrication and Painting - The Chop Shop
Motorized Bicycle Welding, Fabrication and Painting - The Chop Shop Custom fabrication and projects, tanks, frames and more.
Old 04-03-2016, 07:44 AM
curtisfox curtisfox is online now
Default Re: rear suspension #2
Nothing wrong with a tip, mrsfan does it all the time. Looks good to................Curt
Old 04-03-2016, 07:57 AM
cannonball2's Avatar
cannonball2 cannonball2 is offline
You can gain a small amount of clearance by changing the shock to a cheapy spring type, then maybe there is clearance for a Z type manifold?
The stock updraft carb like on my build would probably fit but the angle wouldn't to good.
Old 04-03-2016, 09:30 AM
scratchbuilder's Avatar
scratchbuilder scratchbuilder is offline
Thx guys..considering all options including major surgery..��
Old 04-03-2016, 10:39 AM
Yeah MT..I'm just disappointed I didnt see it. Wondering if a 6"or so manifold with elbows can work.. On the plus side i remembered this tank an that i gave up on it because i couldnt find cap.. then i thought all i have to do is solder a new filler and cap.. Zazaam.
Old 04-03-2016, 11:48 AM
Yes, actually the 6" will improve the low to mid rang, like cannonball said a Z or S shaped manifold.....................Curt
Old 04-03-2016, 12:40 PM
culvercityclassic's Avatar
culvercityclassic culvercityclassic is offline
Default
You can make a curved manifold like I did for clearance, curved the exhaust too.
CulverCityClassic
wolfcreativecustoms.com
Old 04-03-2016, 02:22 PM
Thx ccc..i gotta try that..i might have to ride bow legged..its like there is with me anyway..something ends up causing major..dang it issues..
Old 04-03-2016, 02:26 PM
Another option..except the engine sits higher than i imagined..
File Type: jpg 20160402_183553_1459657527837_1_20160402_220034.jpg (63.4 KB, 27 views)
Old 04-03-2016, 02:35 PM
Hey cb2..i swaped out the shock.. didnt gain a worthwhile advantage. I also swapped the forks to my cheap springer.. took em off my low crusier..put on this build....then remembered why i dont bother with them.. No mountable Brakes!!
Old 04-05-2016, 08:18 AM
I got the g100 running properly. It was a air leak. I kept getting surgeing even after a swap to an nt carb...so i old school gasket shallacked the gasket and varooom. So im gonna see how it fits in place of the briggs.
MotorBicycling.com
