Old 11-22-2008, 09:16 PM
Garrett Garrett is offline
Default 80cc Engine
Hey guys im new here and I want to install an 80cc engine on my Specialized hardrock mountain bike. Its an older model... maybe like 1994-1996 and I was curious to know if the engine would work.
Thanks!
Garrett
Old 11-22-2008, 11:21 PM
biken stins biken stins is offline
Default Re: 80cc Engine
Welcome Garret.
Somewhere on the site or someone can tell you the L,H,W needed.
What size is your bike ?
Where there's a will there's away. Good Luck,
Old 11-23-2008, 12:04 AM
Dave31's Avatar
Dave31 Dave31 is offline
Hello Garrett, Welcome to the forum
Most 24" or 26" bicycle with diamond frame and horizontal top tube should have sufficient space to mount motor.
At least 12.5 inches running along the seat tube from the top of the bottom bracket to the bottom of the top tube.Tubing size from 1-1.5inches on the both the seat and down tube. Plus or minus 70deg. above the bottom bracket between the down tube and the seat tube. Inner distance between pedals needs to be greater than 4.5 inches in width to clear the 4.5inch wide motor.
Old 11-23-2008, 12:21 AM
stude13 stude13 is offline
there are no 80cc engines. sue them for false advertising.
Old 11-23-2008, 04:23 AM
tyrslider's Avatar
Those bikes make great solid mb's
Old 11-23-2008, 08:25 PM
ok... i think my bike is a 26 inch becuz it says 26x1.25 or something on the wheel. Ill take a picture of it and post it.
Old 11-23-2008, 11:17 PM
tyrslider's Avatar
it's most likely a 19" frame / seattube; it'll work great!
Old 11-24-2008, 12:09 AM
ok, do u know if i can adjust the handle bars on a bike like that?i want to raise them up a bit becuz it feels like im riding a crotch rocket haha
Old 11-24-2008, 05:39 AM
Bikeguy Joe's Avatar
You can raise the gooseneck a little on most bikes, but you'd be better off just putting on a set of bars that feel right.
Old 11-24-2008, 05:40 AM
I'm looking at photos of your bike and I think it's gonna be a squeeze to fit the engine in there.....I may be totally wrong but I would check measurements.
