Old 11-12-2012, 12:38 PM
Tinytim Tinytim is offline
Default Parts for china girl motor
I built a motorized bike with a 80 cc china girl engine. Seems that the small gear that meets the clutch flywheel must have vibrated itself loose and stripped out.
Anyone else experience this ever? If so, how have you solved the problem. red Locktite?
Also, where do you buy your china girl parts. I need a crank gear...
Old 11-12-2012, 01:15 PM
ocho ninja's Avatar
ocho ninja ocho ninja is offline
Default Re: Parts for china girl
The small gear is called the bevel gear... My woodruff key shered once and I stripped the threads that gear pulled needs to pull the gear.
I eventually got it out and I bought a replacement from thats Dax, he sells it it together with the gear, woodruff key, and the screw.
Old 11-12-2012, 02:16 PM
Tool Maker's Avatar
Tool Maker Tool Maker is offline
I would avoid red loctite in that location. The gear needs to come off to service the crankshaft.
Use blue (removable type) loctite. Or use some gummy sealer like permatex aviation sealer on the threads &let it dry over night before starting the engine.
