Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > DIY Home Built Motorized Bicycle (non kit)
DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds
Old 10-07-2008, 07:12 PM
Motormaker Motormaker is offline
Default A couple briggs style bikes
Here are a couple bikes I built this summer. I like to try different things mechanically.
This is a 26-inch " La Jolla cruiser" from Wal-Mart. I chose it for it's coaster brakes and no cables, gear changers etc. I like a clean look. It is an aluminum frame, which is a bonus. I used a 3.5 hp Briggs & Stratton engine. A go-kart style centrifugal clutch was used with #35 chain. The "side pusher" type design track's very well. The small tire takes all the weight of the engine so it doesn’t feel heavy when riding.
These photos were taken before I installed a twist grip mini-bike throttle and a handle bar mounted kill switch.
The motor assembly pivots where it mounts to the bike. You lean to turn just like a normal bike with two wheels. The wheel-motor will move in a scissor type action as you lean.
The bike will let you know if you take off to aggressively. The lack of weight on the drive tire will cause it to buck and bounce wildly. However if you give it 4 or 5 quick turns of the pedals then keep a light hand on the throttle she will buzz along at about 24 mph for miles and miles. More on the other bike later. MM
Old 10-07-2008, 07:48 PM
comfortableshoes comfortableshoes is offline
Default Re: A couple briggs style bikes
That is a very nice design for a pusher type motor. I like how tight it is to the bike, very minimal design too. Clean build. I like it!
And it must be a 4 stroke?
Made in china, made better in my garage
Comfortable Shoes Studio Tool Rolls and Pouches
MyMotoredBike.com
Flicker Page
Don't feed the trolls!
Old 10-07-2008, 11:24 PM
stude13 stude13 is offline
thats very cool. i tried to build a pusher last month and it was a complete flop.
Old 10-08-2008, 08:05 AM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
I like that idea a lot.... The more original the idea the better it is in my opinion. Also not to worry about failure when you least expect it something you learned in a failed build will help with a new build. It all about the learning.
Old 10-08-2008, 08:55 AM
vernon/retiredtinkerer vernon/retiredtinkerer is offline
nice job motormaker, simple and slick, i wonder if some kind of shock absorber or spring tension would help it stay on the ground when you want to gas on it??? vernon
Old 10-08-2008, 09:17 AM
OSCAR383's Avatar
OSCAR383 OSCAR383 is offline
Simple I Like It
MEASURE ONCE AND CUT TWICE.......WAIT A MINUTE
Old 10-08-2008, 01:23 PM
Jemma Hawtrey's Avatar
Jemma Hawtrey Jemma Hawtrey is offline
Its a nice machine and a lovely bike - but not all that original in concept.
The Wall Motor Wheel used this system in 1910 with what looks like a solid 16/20 inch wheel and, I think, a 211cc single cylinder motor clamped to the cycles superstructure.
Its actually a full circle job - because the two guys who took over production of the Wall machine were a Mr Briggs and a Mr Stratton...
Incidentally to get rid of the axle tramp on fast starts - you can get hold of the mid frame damper units for MTBs as a replacement unit. Make up a mount to the bike and a connect tho the engine unit and that would help with that particular problem.
Jemma xx
"....Look, no pedals... *thud*..." The mating call of the motorized-biker.
"RetroEagle" - 32cc Two-Stroke, Piped. 35mph on #13 gear. Reversed stem with springer fork.
Old 10-08-2008, 01:59 PM
In reply to "Shoes" Yes it is a 4 stroke. However I am looking into making a two-stroke 50cc version with a pocket bike engine. (To be street legal in Indiana) Another idea I had along these same lines was to use the engine, torque converter, rear wheel assembly from a 50cc scooter/moped. It would just be a matter of simple bracketry. Also in regards to "Vernons" comment: I am looking for a mono-shock assembly from a scooter for that very idea. (Great minds think alike) It will also help with the problem of the whole thing falling over when parked. No "Jemma" the concept is not new at all. The execution is. The Briggs and Stratton motor wheel had the motor situated beside /inside the wheel. The motor wheel also had no clutch. The whole assembly was lifted off the ground to allow the wheel to spin in mid air. My design is much closer to the Popular mechanics/Mechanix Illustrated version from the mid 1950's. I simplified that that design further because I have the ability to weld and with today's aluminum block 4 strokes I could do more with less. And the Popular Mech. design seemed clumsy and inelegant to say the least.
For the unknowing here is the B&S motor wheel for bikes.
There were many uses for the Motor wheel.
Old 10-11-2008, 07:36 PM
could you give us some close ups. i have a boreem scooter. the motor is mounted on square tubing. because of starter im thinking of mounting on other side. did you use a long shouldered bolt as attachment?
Old 10-11-2008, 08:09 PM
Large Filipino Large Filipino is offline
Dude that is AWESOME!!
I could see a shock absorber (with outer spring for rebounding) from even a car halfway down that arm to the upper half of your bike frame.
Man I wish I could weld.
Sorry for my evaluation here because it's a great design but have you thought about theft? It looks like one bolt and it's all theirs.
