View Poll Results: electric starter
Has been done before 0 0%
what is the benifits 1 100.00%
Lot of work, but worth it 0 0%
Better lights and the cool factor of having it. 0 0%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
Old 03-04-2012, 02:53 PM
Donbia Donbia is offline
Default Electric start
Has anyone put an electric starter, IE: small ATV type starter, with a chain sprocket drive on it or modified to work with a pull starter drive. I know that there is a pull starter for there engines.
In saying this there would have to be a battery and a voltage limiter as well as a solenoid. these engines have a generator or magneto to run the coil, which could be used to charge the battery depending on the voltage and amps out.
I have seen this on ebay as a option, but I believe it would not be needed since
the engine already has it.
This would open the door to bigger and better lights etc. Also it is possible to use it with the chain drive. but the bike would need a rear stand, like the old whizzer had to start the engine.
Seems like a lot or work, but the benefits would be worth it not to mention the cool factor.
Old 03-04-2012, 04:58 PM
bandito bandito is offline
Default Re: Electric start
Donbia go to monsterscooter and check out the 52cc with electric start and its only $130.
