Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > 4 Stroke Bicycle Engines & Kits
4 Stroke Bicycle Engines & Kits 4 stroke engine kits are great if you want reliability or do not want to mix your oil and gas. Learn from each other how to get the most out of your 4 stroke bicycle engine
Old 01-08-2012, 12:47 PM
birdmannn101's Avatar
birdmannn101 birdmannn101 is offline
Default Anyone know the difference Honda ghx50 and gxh50qxa
Can't find anything showing the difference between these two Honda 49cc engines but lots of threads for one or the other. Just want to make sure that I get the right Honda 4 stroke engine for my spring build....Dan
Old 01-09-2012, 09:59 AM
The_Aleman's Avatar
The_Aleman The_Aleman is offline
Default Re: Anyone know the difference Honda ghx50 and gxh50qxa
I forgot where I read this, but the "QHA" means the engine has a low oil sensor and you get to pay for it whether you want it or not!
GXH50s have had this for almost 3 years now. Any GXH50 should work for your build.
Meh.
Old 01-09-2012, 10:29 AM
Al.Fisherman's Avatar
Al.Fisherman Al.Fisherman is offline
Both have a Low Oil shutdown.
ghx50 2.1HP, 49.4cc, 12.1#, Height 13.0", Length 8.9", Width 10.8"
http://engines.honda.com/models/model-detail/gxh50
gxh50qxa 2.5HP, 49.4cc 13#, Height: 13.9" Depth (Less Shaft): 7.7" Width: 10.8"
http://www.kit-master.com/web/index....&Itemid=100001
Funny what you can find doing a GOOGLE search....
Looking for HT's parts?
MY PARTS STORE
HT pre instillation tips.
Engine running problems?
HT breakdown Photos
Ron ><)))))*> Calera, Alabama
Old 01-09-2012, 11:36 AM
The_Aleman's Avatar
Honda Engines - Small Engine Models, Manuals, Parts, & Resources
GXH50QXA Honda Horizontal Gas Engine 2.5 HP OHV
No, Ron. Not every GXH50 has a low oil shutdown, they started that a couple years ago. Your links have no relevant information for the OP's question.
Meh.
Old 01-09-2012, 12:22 PM
MotorBicycleRacing's Avatar
MotorBicycleRacing MotorBicycleRacing is offline
This is the right Honda 50 to buy cause it's the best deal!
If you can find a better deal please let us know. All other sellers
want a lot more for the Honda 50. The motors are all the same specs
internally.
Small Engine Warehouse: GXH50QXA - Honda Engine 2.5hp Horizontal 5/8"x1-5/8" Keyed Shaft, Overhead valve LOS 7000 RPM
I think the different letter codes refer to whether the motor
comes with a fuel tank or exhaust, but no one seems to be
selling the bare engine anymore.
Low oil sensors are easily disconnected.
Old 01-09-2012, 12:35 PM
Maybe you should stick to the 2-stroke section. I've already watched you strike out on 4-strokes.
Yes, that may be so (no oil shutdown) years ago, but he is looking to buy one now, not a engine a couple of years old, at least he didn't mention buying a used engine.
Latest information I can find...http://engines.honda.com/models/model-detail/gxh50
Oil Alert
GX series, V-twin series, iGX series
Honda’s Oil Alert system helps to prevent engine seizure due to a low oil condition.
The system consists of an oil level sensor inside the crankcase. When the oil reaches a level that is too low for safe operation, the engine warns you or stops automatically.
MY PARTS STORE
HT breakdown Photos
Old 01-09-2012, 02:48 PM
The_Aleman's Avatar
Let's settle this right now: GXH50 all work the same, some just come with more or less equipment on them.
The last 3 letters in the model are variants. Last 3 letters may or may not be listed. This answers OP's question.
The low oil sensor used to be an option, but about 3 years ago it became standard and the engine price went up.
The days of $200 new GXH50s are long gone
Meh.
Old 01-10-2012, 08:33 AM
Thanks for all the input. So, this answered my question. The QXA has a little more HP than the old 50 and is .9 inches higher which should work on a cruiser frame. Planning to use the Q-matic or 4GT with $20 upgrades. Going to try the carb on the engine with the throttle kit first.
Thanks again for all your help....Dan
Old 01-10-2012, 11:51 PM
bandito bandito is offline
The differences are in shaft sizes. Length, od, for various apps.
Old 01-11-2012, 07:41 AM
Some have 3/4 shafts, tapered, 5/8ths etc. the letters after the gxh 50 tell you exactly what it is.
MotorBicycling.com
