Old 06-07-2015, 01:05 AM
dtv5403 dtv5403 is offline
Tonight I finished truing my custom wheel set that I'm building for my upcoming project. The front is a 130mm dirt bike drum, and the rear is a 90mm moped drum, both laced to 24" steel bicycle rims with 11g spokes. The front hub was given to me by a very good buddy, and the rear hub was purchased brand new, I got it in a trade. I like the front hub simply for its size, its 1.5 times bigger than the biggest bicycle drum available. I'm expecting stopping power that is comparable to disc with this big drum. I like the rear hub because the drive sprocket bolts directly to the hub via six mounting holes, making it far superior to any sprocket adapter or rag joint. I trued them in the rear of a bicycle frame, using a c-brake with the brake pads as feelers. At first I tried using both pads at the same time, thinking I could get it done faster if I could true both sides of the rim simultaneously, but what I discovered is that when you get both pads really close to the rim, its very hard to tell which side of the rim is rubbing on the pads, especially in low light. So I used one brake pad at a time. I did not use a brake cable to squeeze the pads against the rim, I just tightened down the nut that holds the brakes to the frame. The front wheel gave me a spot of trouble, but I figured it out. The first time I trued it, I was finding loose spokes on one side of the frame, and spokes that were way too tight on the other. What I did was loosen the two spokes closest to the loose spoke, then tighten the loose spoke, then tighten the two spokes closest to it. By doing this, I was able to get the spoke tension much more even. Now I need to trim the spoke ends because they were a little long, but they were the shortest 11g spokes I could find. I looked into custom spoke lengths, but none of the websites I found offered 11g spokes. Anyway, pics of the wheels can be seen in this thread: www.motorbicycling.com/showthread.php?t=58962
Old 06-07-2015, 01:31 AM
DRBS's Avatar
DRBS DRBS is offline
wow that's going to be a stop on a piece of hair bike LOL **** with stop on a dime
hang on a second I think ill use my nox now
Old 06-07-2015, 01:47 AM
My thoughts exactly, lol. Thank you.
Old 06-07-2015, 01:03 PM
Davezilla's Avatar
Very nice wheel set... you shouldn't have any trouble stopping with that setup...
Old 06-07-2015, 01:12 PM
Thank you for the compliment
Old 06-07-2015, 09:51 PM
Panhead's Avatar
Panhead Panhead is offline
Did a bit of tightening up, & after watching the AGC video on fooling with air filters, carbs, etc. I gave the ol' soldier a larger jet. Then I proceeded to head for the outskirts of town, where I ran out of fuel. I am going to have to get into the habit of pulling the cap on that teeny-weeny tank BEFORE I leave the house.
This is especially true when I'm doing things that may affect fuel consumption.
Old 06-08-2015, 12:35 AM
Davezilla's Avatar
Did some ebay shopping and got me a really cool frame to transfer all my parts to so I can replace my cracked frame with a full suspension frame... I've been looking for a good full suspension frame with an open front triangle for easy engine installation and this specialized just got my attention... http://www.ebay.com/itm/261915582302...%3AMEBIDX%3AIT
Hopefully I can make time to get my front end and other parts transfered over to this frame then put my engine back in so I can rip it up to the taco shop in the mornings again...
Old 06-08-2015, 01:08 AM
Sweet frame at an excellent price!
Old 06-08-2015, 01:11 AM
DRBS's Avatar
i know what you mean i too tried that opti and didnt like it i use amsol dominator racing oil 3oz to gal from the kawasaki dealer its 9.99 a QUART not a pint or a 3 oz bottle besides its red so i tell ppl that they run on blood sweat and tears but isnt that the truth??? but just remember its your choice what you use
Old 06-08-2015, 01:16 AM
DRBS's Avatar
do what i do sometimes look on craigslist and get a vintage 60's-70's "ballon" tire bike there tough ride like a drean and can handle tons of torque just dont forget to take the bearing nuts loose and pack some lithium based grease into the axles try to fill them good they will last a loooong time if you get them full
Tags
MotorBicycling.com
