Old 07-04-2013, 01:12 PM
dodge dude94's Avatar
dodge dude94 dodge dude94 is offline
Or it could be like this:
http://www.youtube.com/watch?v=fAsbm...ature=youtu.be
2 WHEELS: '11 Huffy Good Vibrations, '11 Skyhawk GT5, 44t, CNSV2, NGK BPR7HIX, Bosch wire, shutupexhaust, 26x1.75kevlar tires, Tektro C230's, new stupid Bell chain
Old 07-04-2013, 05:59 PM
xseler's Avatar
xseler xseler is offline
Last couple of times I rode, I noticed this weird 'squeak/creaking' noise. Tracked it down to the front wheel. Pulled the front wheel off, and the wheel didn't want to rotate on the axle. I never had been into the hub of this wheel, so I just thought that the factory over-tightened the cones.
Well, just to be safe, I removed everything to make sure there was enough grease on the bearings. As I loosened the cone, one of the ball bearings fell out. Hmmm.....bad bearing, I thought. Turns out that Huffy doesn't use a capture collar for their front ball bearings!! They were just loose in there! I guess I'm off to my LBS in the morning to see if I can fit a regular bearing in this hub............I'm assuming that Huffy saved about 10 cents a bike to omit these parts. I guess that the majority of their bikes don't go far enough for people to find this out.............
You're never lost until you run outa gas.
Old 07-04-2013, 06:05 PM
maniac57's Avatar
maniac57 maniac57 is offline
Unless there WAS a collar that got ground up, not having a retainer is not that big an issue. Some very high quality bike hubs use loose ball bearings. (cant remember names but good stuff)
Opinions vary, but I'd just use them as long as there is no damage to the races or cones.
If more is better, then too much is just enough.
If you can't afford it, build it yourself.
Old 07-04-2013, 06:06 PM
Just curious, what is the year of manufacture on your bike? Mine is a 2011 and I haven't been into the front hub yet, but the bike guy at Academy where I bought it from has. Dunno what all he did...
Old 07-04-2013, 06:10 PM
xseler's Avatar
I probably got it in 2010 or 2011. It was a Huffy "Big Daddy".
I wonder if I could go to a specialty bearing place and find a sealed roller bearing to fit in the hub......that would certainly be a permanent fix.
Old 07-04-2013, 09:03 PM
d_gizzle's Avatar
d_gizzle d_gizzle is offline
Exseler,you might be able to use hollow hub trike bearings. Tractor supply has them in the 'hard to find' drawers in the hardware section. Then you're gonna need an axle for a sealed bearing wheel,such as a Currie electric scooter wheel,12" aluminum alloy wheel for reference. Now if I could remember the bearing size....
Old 07-04-2013, 09:24 PM
Well, mine was bought summer of 2011. So I guess I have something nice to look forward to when I freshen that hub.
Old 07-04-2013, 09:42 PM
Nunyadam Nunyadam is offline
only thing i did for my bike was educate myself, still waiting for my kit. (is it the 9th yet?)
Old 07-04-2013, 09:46 PM
Moto's Avatar
Moto Moto is offline
Just bought this: http://www.aliexpress.com/store/prod...692935087.html
SOOOOO EXCITED!!!!! AGHHHHHH
Old 07-04-2013, 10:49 PM
mapbike's Avatar
mapbike mapbike is offline
what intake do you plan to use and do you have a good source for the cables?
I'm really interested in that carb also.....
Map
Tags
MotorBicycling.com
