Old 05-11-2013, 08:05 PM
577-Jersey's Avatar
577-Jersey 577-Jersey is offline
Well lets see,,
What did i do today,,
That luckyearlybird motor I just finished runs so good on the huffy Im gonna sell,,i swapped it out with the Grubee motor on my Trek..other than that gotta get back to my broccoli rabbi,chuck steaks,and Blue Moon
Good Times....
Ghost pedaling in NJ....
Old 05-11-2013, 08:06 PM
obesepolice obesepolice is offline
Decided I wanted to rebuild my bike again to enter the build off on RRB. Here is the latest mock up. still waiting on a few parts. But I really like it so far.
http://www.ratrodbikes.com/forum/vie...p?f=76&t=72339
Old 05-12-2013, 01:09 AM
Jbomb's Avatar
Jbomb Jbomb is offline
Upgraded to the CR Machine Stage 1 top end with 6cc combustion chamber (GT5 engine). Top of my jug is milled, so greater compression pushed my requirements past the 91 octane rating of premium pump gas. I now have to run racing fuel, but man is it worth it! Left a few scooters in the dust on the test ride today!
Old 05-12-2013, 01:19 AM
Trey's Avatar
Trey Trey is offline
$50 Cruiser
Well over 20 miles of pleasant country roads. I love this thing we do.
Misaligned rear tire equals picture one.
I never intended to leave my bottom bracket like this, but...
It's cooler to not fall off your bike.
Old 05-12-2013, 11:50 AM
bigbutterbean bigbutterbean is offline
Insulated the wires connected to my headlight switch, because I had noticed last night that after it had been raining, my headlight had a dim glow even though it was switched off. I also went to great pains to find a good ground for my brake light after noticing that it wouldn't always work right. It seems to be working well now. I also had to cut some new rubber mounting shims for my tail light after the ones it came with fell out. I taped the new one on so it won't fall out again.
Old 05-12-2013, 12:17 PM
Trey's Avatar
$50 Cruiser
BBB- Electrical is an ongoing tragedy man, glad you've got it worked out.
Old 05-12-2013, 12:45 PM
happycheapskate's Avatar
When I was riding the HT bike, I had all lights run with 2 wires (1 hot, and 1 ground back to a single ground screw near the engine. ) That took care of computer glitching and blown bulbs.
1" roller Dax Friction Drive and Tanaka 3300 with mods.
Old 05-12-2013, 01:17 PM
GAS+RIDEZ's Avatar
GAS+RIDEZ GAS+RIDEZ is offline
Today take the bikes for a spin,GT5 ran without difficulties came without the chain cover screw, then whizzer ran good but when I go 35-38 miles seems as if the carb runs out of gas because it stops accelerating,then I stop to accelerate and re-accelerate again and does the same at 35-38 miles,what could it be ,thanks in advance.
Old 05-12-2013, 01:24 PM
Lol, my electrical system is kind of a mess but it works. Here is how I have everything set up. I have 3 7.2v nicad batteries strapped to my luggage rack. One powers my brake light and the other two, wired in series, power my headlight. I have the ground cable for my headlight running to my fork. My brake light is automatically grounded because its metal. I have two wires running from each of my switches, one switch for my headlight and the other for my brake light, which is built into my brake lever. One wire from each switch is connected to the light it controls, and the other to the battery that powers it. I have a ground cable running from each battery to a separate grounding point, because I found that if I ground them both at the same place, one light or the other will not work. The batteries are connected to the wires via quick disconnects, so that I can easily remove the batteries. I charge them inside when they need charged. I have two chargers, one is a 5 hour charger and the other is a 15 minute charger.
Old 05-12-2013, 01:27 PM
5-7HEAVEN 5-7HEAVEN is online now
I'm on this computer, and my bike is an arm's length away. It's 7am. Everyone's still asleep. Mother's Day luncheon is at noon. I'm gonna ride to McD's soon, which is less than a mile away.
Tags
MotorBicycling.com
