Old 03-20-2013, 07:51 AM
Russ McClay's Avatar
Russ McClay Russ McClay is offline
Originally Posted by croblesjr View Post
Hmm good question about the fuel filter. I've taken the carburetor apart before and cleaned it up after the first time. I guess I just over looked something I'll go over it again just have to wake up before everyone else does in the house to be able to do anything to the bike. I'll give it another go.
Not sure what kind of carb you have, but my first one (66cc/NT) had a leak in the plastic float which allowed gas to get inside it, which weighed it down, which caused gas to flow out of the air filter (through the overflow hole). Changed that and all was well.
Old 03-20-2013, 08:13 AM
ResetBTTN's Avatar
ResetBTTN ResetBTTN is offline
I've had one good ride out if my Grubee skyhawk GT5 since finishing the build on Sunday. Yesterday I go to get another ride out of it but I tighten up the exhaust bolts first. Jim, at pedalchopper.com let me know to tighten them up after the first few rides.
Anyway I'm tightening the bolts and notice one bolt isn't locking. Long story short I back it out and shine a light into the hole and its nearly threadless.
Afterwork today I'll be getting a tap&die set and getting it back to running.
YouTube Video
http://www.youtube.com/watch?v=L_qgiD6xAk8
{~If at first you fall off just hit your ResetBTTN~}
Old 03-20-2013, 11:44 AM
killercanuck's Avatar
killercanuck killercanuck is offline
That suck Resetman, you should just get a single tap for like $5 now, and wait for the whole set when they go on sale. $_$
Being the first day of Spring(woo!), got in the mood to tinker on something. Will be doing a reverse jug mod for the 29er with a replacement engine after the aluminum can head gasket debacle... (still gotta split that case to get all the fragments out, hopefully salvage it)
So, started with cleaning the transfer ports. They were maybe 85% open due to slag... bleh. She'll be a happy camper now:
Cards, 29er, Trailer, Hack'em'up
Build with pride! Build to ride!
"A clean shop is a sure sign of a cluttered mind" ~ fasteddy
Old 03-20-2013, 12:44 PM
ResetBTTN's Avatar
Killercanuck that does suck. I already got a set from work I'm gonna borrow for the job. It being the first day of spring I would rather be riding it after work! Good luck with that tinkering you got going on.
Old 03-20-2013, 11:25 PM
fatdaddy's Avatar
fatdaddy fatdaddy is offline
I've found that if you screw the stud in tight then it has nowhere to go when things get hot and start expanding. If the stud is already bottomed out then when it expands it has nowhere to go except harder against the threads and tends to strip them out easier. I run the stud down, then crack it back just a little. I haven't stripped out a stud since I've been doing it this way.
fatdaddy.
Old 03-21-2013, 04:43 AM
ResetBTTN's Avatar
Fatdaddy I'm gonna take that advice once I get that hole re-threaded. I wanted to get to it afterwork but you know how issh* comes up and plans get averted. Looking like its gonna be a weekend thing but its cool because I'll have more time to get it right.
On the plus side though I did get my rear fender cut to stop that chain from rubbing it on the engine side. So that's why I did to my bike today.
Has anyone done something different to stop their chain from rubbing?
Old 03-21-2013, 11:22 PM
Skarrd's Avatar
Skarrd Skarrd is offline
Got a right angle adapter for my dremel. C:
I'll have to see how well I can use it to get at the transfer ports.
They see me rollin'
they hatin'
Originally Posted by biknut View Post
Traditional bicycle riders think we're cheaters. Non riders think our bikes are toys. Bicycle shops think we're a threat. Tree huggers think we're polluters. The police don't know what to think.
Old 03-22-2013, 03:25 PM
Wickedest1's Avatar
Wickedest1 Wickedest1 is offline
Installed my new ngk b6hs...gapped to .028...suppresor boot installed as well...threw on a heavy duty front wheel and new rubbers all the way around...repacked rear hub...charged my battery...more duct tape...painted my tank, headlamp and fender satin blue the day before yesterday...found 2 springs that are 1" and are 75lb springs...spring loaded idler here I come...and I ordered 2 bp6hs ngk plugs and a suppressor wire from the zone
oh...and I rode her hard for about a 1 mile loop...nice...
Thats a lot of moving parts...hope it all works...
FD4E
Old 03-22-2013, 04:16 PM
Woo! Duct tape!
Still plugging on the Bairdwards mod, as Aleman put it, apt, eh.
Before:
After:
needs more finishing, but getting there...
Old 03-22-2013, 08:34 PM
VIKTR VIKTR is offline
Put a piranha throttle on the cruiser
Fiddled with the mountain bike, jetting and re-jetting the RT carb, switching back to an NT carb, changing fuel ratios, searching for air leaks... and still not able to keep the engine from bogging down on hills
Thinking about swapping engine with a spare I have laying around.
Tags
MotorBicycling.com
