Old 12-06-2011, 03:55 AM
frozenveinz's Avatar
frozenveinz frozenveinz is offline
Nice engine there 2239968, what you gonna put it on? Anyway, today I gave my bike a complete tuneup. Cleaned the carb, adjusted cables, cleaned/greased chain, cleaned/greased clutch gears, cleaned/greased pedal chain, adjusted clutch, put cardboard in the clutch cover, glued mousepad to outside of clutch cover, mixed gas, filled tank, steel wooled any rust i found on anything, etcetc. Hopefully my morning test drive shall yield smoother, quieter, and maybe even stronger operation.
Pics: Tune Up pictures by frozenveinz - Photobucket
Jus Keep Cruisin!
Old 12-06-2011, 10:40 AM
rob.smith rob.smith is offline
finally got a new tire for my bike last night and went out for a little snowy road, -1 cruise
Old 12-06-2011, 01:45 PM
KDB's Avatar
KDB KDB is offline
I ride home after work on unlit country roads so I went to the dollar store and loaded up on LED flashlights and AAA batteries. Then I duct taped them to my helmet. The whole thing looks like a really bad spaceman costume but it puts out a lot of light.
The headlight only lights where your bike is headed but a helmet light points where you are thinking of riding. I can look to my right to see if I have any pavement over there.
Makes the ride safer and less stressful.
Old 12-06-2011, 01:50 PM
UriDead's Avatar
UriDead UriDead is offline
Originally Posted by frozenveinz View Post
Looked at the pics... OK, have to ask... what does the clutch cover say that is so secretive? :-)
Old 12-06-2011, 06:53 PM
Jumpa's Avatar
Jumpa Jumpa is offline
Thats put on to cut down on noise vibration I used an old mouse pad on mine
Old 12-06-2011, 06:56 PM
Jumpa's Avatar
Originally Posted by 2239968 View Post
Received a fun package today. One step closer on my build.
With the kick start i love it ...where do I get one and how much was it if you don't mind me asking?
2239968 2239968 is offline
It will go on a boxer mountain frame first. Then once spring comes around it will go on one of Dan Orabona's Board Tracker frames.
Old 12-06-2011, 07:03 PM
I got mine from Dan. He got my a really good deal. Thats probably all I should say lol
Old 12-06-2011, 07:10 PM
diceman2004's Avatar
diceman2004 diceman2004 is offline
I like that skull and cross bones noise dampener ... nice idea on the mouse pad .
Old 12-06-2011, 07:59 PM
How hard is it to mount a morini?
My muffler endcap came off so a made a new one. Used a small spray shoe cleaner can with the aerosol tip side cut off. Drilled a 1 cm hole in the center of the remaining side, with smaller 1mm maybe 2mm holes surrounding it. Maybe 8 little holes plus the big one. I call it the 8+1 endcap. Slid it over the muffler and hose clamp, very tight. Works great, I can now climb hills with no pedal assist that i needed to before, and it starts going much better. Also the exhaust note is awesome. The longer the can is sticking out from pipe the deeper it sounds(no clue why, someone educate me).
Jus Keep Cruisin!
Tags
MotorBicycling.com
