Old 10-26-2010, 05:14 AM
Mac's Avatar
Mac Mac is offline
I kept looking at a spare 49cc scooter Magnito... I could make this work... has a lighting coil also. rode 10 miles in a medium cold mist. BTW, Tom, I think your beyond efficient, not only have you used every bit of the horizontal space in the workshop, you use the vertical space as well!
Mac
Old 10-26-2010, 05:20 AM
breno's Avatar
breno breno is offline
stood there wondering if its worth turnin the grubbee pipe backwards like the way its supposed to look
-> Reading this signature was pointless <-
Old 10-26-2010, 04:59 PM
Skarrd's Avatar
Skarrd Skarrd is offline
took it for another ride just for the **** of it. need to raise the idle slightly since it would stall out toward the end, and need to find a larger petcock for it than the one provided since i got it to bog down a little from constant cruising.
also need to figure something out for the front mount. been running without it since it sat in there quite nicely, but didn't have enough room for the universal plate, and not enough room to use studs.... hhhmmm. also need to take out the broken bolt in the mount from the attempt at putting it on the chopper, snapped a bolt head off in the engine's front mount hole. that's going to be a ***** getting it out
They see me rollin'
they hatin'
Originally Posted by biknut View Post
Traditional bicycle riders think we're cheaters. Non riders think our bikes are toys. Bicycle shops think we're a threat. Tree huggers think we're polluters. The police don't know what to think.
Old 10-26-2010, 08:12 PM
Tim_B_172's Avatar
Tim_B_172 Tim_B_172 is offline
Totally disassembled my engine to correct a crankshaft imbalance. Found the counterweights to have CASTING SAND in the cut outs. Found a few other problems which indicate that I need to replace the whole crank. I'm now waiting on some answers down in Norms 2 Stroke Repair before I decide which crank to order.
Old 10-26-2010, 09:55 PM
Dan's Avatar
Dan Dan is offline
Staff
Cleaned the carb out again! 2ce. Drilled 1/4 hole in the tank cap. Swapped out the stock china girl pet-cock for a 1/4 brass nipple. Changed the fuel filter. (all after Kreem coating tank) Just to come to the conclusion (again) that the spring in my clutch, when warm or hot, is too lose. One very expensive spring, snork (In it's defence, in it's early life I beat on it trying to kill it to see, what oddly enough would kill it. Turns out, I found out)
Sad part, man I love these things!
worst apocalypse ever
http://www.youtube.com/watch?v=y6Sxv-sUYtM
Old 10-26-2010, 10:03 PM
bairdco's Avatar
bairdco bairdco is offline
a guy who makes cool bikes
finished a copper tank for aztoker, then looked at my new bike for a minute, deciding if i wanted to start on that tank, then said #%$! it, and jumped on my old bike and rode through a whole tank of gas.
i haven't ridden enough for myself lately...
Old 10-27-2010, 12:11 AM
FreeWheeler FreeWheeler is offline
I got it running right, thanks to some great suggestions from bairdco, GearNut, Dave31, and my genius attack cat. I was running with no air filter to test and dont want to ruin my engine, so after following lots of advice it ran right. As for the cat, she saw me messing with the air cleaner and ordered me to feed her and that was when the idea came. Her food container is the same diameter as the NT cleaner housing. She got her food and I got a velocity stack over top of the NT air filter and everybody's happy.
Here it is, works as good as no filter. I will probably be disappoointed with when my expensive filter arrives.
Old 10-27-2010, 04:25 PM
Skarrd's Avatar
decided to take the carb off, and pull it apart to make sure everything is as it should be. then got the front mount bolted to the frame *used the universal plate and the hole in the frame for the cup holder*
but now i think i might have put the float in upside down (if that's even possible) since now it won't run past maybe 1/3 throttle. runs fine at idle, but when in gear it has no power at all.
They see me rollin'
they hatin'
Old 10-27-2010, 04:57 PM
Waiting up for parts to convert to NuVinci hub, so I fixed what I have for now.
Last week, there was major vibration and wobble at the bottom bracket and shift kit location. I removed the freewheel mechanism, and sure enough, it had failed. While inspecting everything, I also detected a CRACK! on the 22-tooth bicycle chainring!! This 22t sprocket is actually a thin cassette cog. Couldn't find a replacement, so I ordered a SBP 24-tooth chainring. I just need to drill four bolt holes into it, since this sprocket is a 5-hole cog and I use a 4-hole freewheel mechanism in my shift kit. All gear ratios will rise a little, but no biggy.
FYI, I run a GP460 4.2hp engine with Scooterguy frame mount, shift kit and 8-speed road bike cassette. The Happy Time expansion pipe fits perfectly onto my upside-down engine. Its headpipe fits great between engine and 4-liter HT fuel tank. Power is awesome, and the bike performs like a small motorcycle.
Old 10-27-2010, 05:25 PM
timboellner's Avatar
timboellner timboellner is offline
Found my left peddle loose, so I tightened it (left hand threads).
Then realized it's stripped out... S.O.B
I'm gonna look like a fool riding a bike with one crank arm til I get a new one.
Tags
MotorBicycling.com
