Old 09-26-2010, 09:48 PM
WaterDog's Avatar
WaterDog WaterDog is offline
Default Good pic of carb pieces???
Throttle handle installed fine, but it wont pull the carb cable. I think i have some pieces backwards inside the carb. Not sure if the spring, pin and washer are backwards. Just need a good picture. didnt pay attention when i took the pieces out to install the cable. Yeah, first time build.Thx.
Old 09-26-2010, 11:27 PM
Upper Class White Trash's Avatar
Upper Class White Trash Upper Class White Trash is offline
Default Re: Good pic of carb pieces???
needle goes in the slide then the washer.
cable goes through spring then in the cut out slot
in the slide so spring is on top of the washer
hope it helps..
my engine isn't leaking!! it is marking it's territory!!
Old 09-27-2010, 01:35 AM
Mind_Reader7's Avatar
Mind_Reader7 Mind_Reader7 is offline
