| Mounting Techniques Every frame is different. Share and ask questions about mounting your motorized bicycle engine kit to your bicycle frame or bicycle rack |
07-11-2008, 04:10 PM
Just how wide is a Wide Pedal Crank?
The title says it all.
I'm looking at mounting a 4-stroke with a centrifugal clutch in the frame. I assume the wide pedal cranks are provided to ensure the crankarms miss the sides of the engine. Anyway, has anybody actually measured the Q-factor of these cranks?
I'm looking to motorize a ten year old GT with a standard UN-72 square taper bottom bracket. It's a triple crank that would be converted to a single ring in the front. I already have a much wider bottom bracket that I could use to put the crank arms out another half inch or more but I need to know how wide is wide enough.
07-13-2008, 08:28 AM
Re: Just how wide is a Wide Pedal Crank?
I guess it depends on the design and engine placement. I run a wide bb, 127mm, but this doesnt clear the motor. I placed the motor forward and higher so the cranks clear. Most frames dont have room for the motor in this space so you may need an x/large frame or custom made.
07-13-2008, 09:55 PM
If 127mm doesn't clear the motor for you, I'm pretty sure I won't make it either. It looks like I can fit a 48cc 2-stroke in there if I can find a clutch actuating mechanism that I like. I don't want two levers on the left side and since I'm a cyclist first, I don't want to get used to braking solely from the right.
07-14-2008, 12:22 PM
The Optional Wide 3-piece crankset offered from GRUBEE and other vendors are designed to clear the Honda GXH50/Clone motor and its attendent gearbox. This set-up is 9.5 inches wide. The wide crankset is designed to clear this with what ever square tapered BB your bike has for its existing crank set. The wide crankset is also a single 44t sprocket. Just changing to a longer spindle isn't even close and would cause chain line problems for the pedal side as well if you could find a spindle long enough.
ocscully
Just
07-14-2008, 12:58 PM
My Honda GXH50 plus a GruBee gear box is 232mm (9 1/8") at its widest point. Below the bulge for the bearings it is only 222mm (8.75")
My three piece peddle set clears 229mm (9")
The one piece that I could not use is 225mm (8.75")
I just installed the wide cranks yesterday on the 38mm (1.5”) factory lower bracket. The one piece crank requires a 51mm (2”) lower bracket to fit through and use the bearings that come with it.
The attachment is a picture of the new wide cranks. Jim
Easy does it, but do it!
07-23-2008, 07:24 PM
Dealer
Cachehiker, contact me if you like, I have Rotary clutch handles (match the old-style throttle)
Mike
10-19-2008, 09:09 PM
Hi jimraysr. Where did you get your cranks?
I want 2 ride my bicycle
10-20-2008, 01:31 AM
Spooky Tooth. Think they were $20. Just the two cranks that fit on the square spindle of the lower bracker. The type that have internal threads for a removal tool and are retained by a bolt into the spindle. Good Luck.
Trying to find these parts often seems to be the most time consuming part. Guess I am going to have to buy a minil beer keg and make my own round tank to go behind the seat?
Jim
10-20-2008, 05:05 AM
Thanks Jim.
Your right about the time used for just finding all the stuff that will play nice together. Can be maddening.
10-20-2009, 11:41 AM
Jim
Hi Jim, Nice pedal cranks you have.
I don't see these on Spooky Tooth's online parts list. (only the one piece crank set) Did you have to call Spooky's for them?
| Thread Tools |
| Display Modes |
Linear Mode
