Old 05-20-2010, 11:47 AM
jared8783's Avatar
jared8783 jared8783 is offline
Default sprockets for manic mechanic adapter
does anyone know where to get sprockets for manic mechanics adapter from?
i know pirate cycles has them but they only have 36, 40, and 48 and i need one somewhere between 54-60 ,
i know you can obviously get them from manic mechanic but there is no telling when you will receive those
also, does any one have any tips on buying another sprocket and drilling the holes for the adapter?
i have a 44 tooth from manic that i guess i could use as a stencil but am still concerned on how i will center the holes properly
has anyone done this before?
how did you do it?
thanks
jared
a square is a rectangle but a rectangle is not a square
Old 05-20-2010, 06:34 PM
NunyaBidness's Avatar
NunyaBidness NunyaBidness is offline
Default Re: sprockets for manic mechanic adapter
That is a good question and one I am interested in as well. Maybe someone that knows will chime in with some ideas.
Old 05-20-2010, 08:45 PM
jsk9782@sbcglobal.net's Avatar
jsk9782@sbcglobal.net jsk9782@sbcglobal.net is offline
use a punch,to get the holes true.Center punch.hope that helps.
Old 05-20-2010, 11:52 PM
jared8783's Avatar
i am not worried about how i will make the holes
what i would be worried about is how will i center the holes properly
Old 05-20-2010, 11:57 PM
Cabinfever1977's Avatar
Find something that is the same size as the inner hole on the sprockets(like a wheel hub)
lay wheel flat on floor, place new sprocket on hub, place old sprocket on top,clamp and mark holes, then drill, or
screw or bolt both sprockets together(while lining up center hole) to a work bench and center punch, and drill.
Old 05-21-2010, 12:04 PM
Kevlarr's Avatar
Kevlarr Kevlarr is offline
Do all that but also order one from MM too that way you'll have something to use until you get one of his perfectly made sprockets.
Old 05-21-2010, 02:21 PM
NEAT TIMES's Avatar
NEAT TIMES NEAT TIMES is offline
A Set Of Center Finder`s Is Very Handy. I Have Found Mine Very Handy For 45 Yrs. Ron
PUMP YOUR BRAKES HAVE TO LOVE WINDOWS & THE INTERNET
NEVER BEAT ON IT, GET A BIGGER HAMMER
"A MAN WHO SAY`S IT CANNOT BE DONE SHOULD NOT INTERRUPT A MAN DOING IT"
Old 05-21-2010, 11:33 PM
jared8783's Avatar
Done did that over 2 weeks ago
sad thing is I ordered a clutch cable for my bug on monday and that came today (friday)
Old 05-21-2010, 11:34 PM
jared8783's Avatar
what are these center finders you speak of?
where would i find myself a set?
Old 05-22-2010, 07:26 AM
NEAT TIMES's Avatar
Jared, The Center Finder`s Looks Like A Set Of Drill Bits In The Metal Stand Up Rack, Up To 1/2 Inch Dia.. For Example, If You Need To Find The Center Of A 1/2 Inch Hole , You Would Use The 1/2 Inch Center Finder, It Has A Cener Punch On The End. If I Find A Link Will Post It. Maybe Harbor Freight! Ron .
MotorBicycling.com
