Reed valve - Wikipedia, the free encyclopediaReed valves are commonly used in high-performance versions of the two-stroke engine, where they control the fuel-air mixture admitted to the crankcase. As the piston rises in the cylinder a vacuum is created in the crankcase beneath the piston. This vacuum opens the valve and admits the fuel-air mixture into the crankcase. As the piston descends, it raises the crankcase pressure causing the valve to close to retain the mixture and pressurize it for its eventual transfer through to the combustion chamber.
It might breath fairly well?i defiantly think Daves looks great but its to big inmo, some people like it like that i guess.
Yes this can be relative to the retrofitted jug on a china H.T. motor. Different things achieve different results across a given power band. Still engines that were designed for it from the drawing board like some other motors are designed differently. There are case inducted reeds.yea i guess, but having it external rather than internal might have a small impact of performance since the whole idea of reed valves are to not let any mixture outside of the cylinder
Hi Rocksolidperson, u had run ur motor for considerable time b4 adding reeds, & when u added them u did so without doing any other mods & havent stuffed the cases, is this correct? How much of a difference did the reeds alone make. I ordered a reed kit last Friday so they should be here during the week. Cheers
