Old 06-07-2008, 07:17 AM
MarkTur's Avatar
MarkTur MarkTur is offline
Default Tachometer
Hi All,
Just wondering a bit now that I'm finally trusting my HT motor, and starting to cruise a bit faster.
I'm using a 44t BoyGoFast motor/sprocket...at about 25mph, I start getting vibration and the motor is turning pretty good. I have absolutely no idea how fast it's turning, nor what the recommended RPM range is on these motors.
So I'm thinking a tach would not be a terrible addition as long as it's not going to be a pain or a load of money to install.
So please, point me in the right direction here...or at least tell me I'm not going to turn my motor into an explosive device by going faster than 25mph. I know I can turn the throttle open a lot more, but it's not going to stop me from over-revving, right?
Thanks,
Mark
Old 06-07-2008, 07:57 AM
Ghost0's Avatar
Ghost0 Ghost0 is offline
Default Re: Tach for HT 2-strokes?
Try this.
Standard Tiny-Tachâ„¢ Digital Tach & Hourmeter - Gasoline Tachometers - CBXManMotorcycles.com
Old 06-07-2008, 09:02 AM
MarkTur's Avatar
Sweet! I'll get it.
Now...what IS the correct RPM range for the motor?
Old 06-07-2008, 09:14 AM
Ghost0's Avatar
Range? Don't know but people that have tachs usually say that around 6000 rpm they start sounding bad but that is usually due to poor balancing. Some can go as high as 7000 but even though I don't have a tach I would guess I keep mine under 5500 rpm. With my tuned pipe I would say my powerband is somewhere between 4500 and 6000 rpm. After you get your tach let us know what you engine likes.
Old 06-07-2008, 09:25 AM
MarkTur's Avatar
Ghost - what rear sprocket are you using?
I just told my wife to get me the tach for Father's Day next week, so I'll let you know in a week or so.
Old 06-07-2008, 11:20 AM
Ghost0's Avatar
I have gears so what sprocket size do you want me to have. I can go between a 58t and a 27t in standard rear sprocket terms.
Old 06-07-2008, 02:53 PM
MarkTur's Avatar
Well, I'm just trying to get an idea of what "should" be for stock setups.
Multiple gears, eh? Doesn't that turn it into a motorcycle?
Cool, though...how fast do you fly with it?
Cya!
Mark Turkel
http://www.AreWeOnline.com
http://www.PalmBeachSoftware.com
HT 70cc ...lots of extras
Kulana Moon Dog Aka BLUE DOG
Like someone else said "Sticking it to the Man!"
Old 06-07-2008, 03:40 PM
Ghost0's Avatar
My bike in 4th gear has a ratio of 4.36:1, about the same as a stock 44 tooth. 25mph is a good speed for that gear so I would guess that the motor is turning about 5500 rpm. Again I don't have a tack but I bet it is a pretty good guess. When you get yours let me know the rpm you are at using a 44t and 25mph.
Motorcycle? Depends on the laws I guess. You can check my bike out here.
http://motorbicycling.com/f15/ghost0...uiser-903.html
Looks like a motorized bike to me.
Old 06-23-2008, 12:56 PM
Bikeman08 Bikeman08 is offline
Default Tachometer
Has anybody ever installed a tachometer on there bike and if so where did you get it and for how much????? Was curious reading the online intructions for the engine i have not yet received but on it way (excited) tells me about the idle speed etc............ So how am I to know what the speed of the motor is.
Old 06-23-2008, 01:39 PM
Dave31's Avatar
Dave31 Dave31 is offline
Default Re: Tach
Well, I keep saying I'm going to get it and put it on......so far have not...but this is what I liked to use....
Digital Hour meter and Tachometer/ 2-4 stroke's
Digital Hour Meter and Tachometer | Hour Meters + Gauges | Northern Tool + Equipment
I'm sure other place's may have this...and maybe cheaper
