Old 04-28-2013, 11:25 AM
rustycase's Avatar
rustycase rustycase is offline
Gutter Rider
Default Re: Motorized Bicycle Take a Tip...Leave a Tip
That's a great tip, Dave!
...I wonder if there will be any probs because it is not fuel/vapor rated???
Will you report back on how long it holds up for you?
if it breaks down, I wonder if it will send pieces of rubber into the cylinder??
tnx!
rc
My goal is cheap, reliable, personal transport, below the tax collector radar. Fun counts for a lot!
Old 04-28-2013, 12:12 PM
SuperDave's Avatar
SuperDave SuperDave is offline
It turned out it wasn't a leak from the carb/manifold (no discernible change, still ran lean & runaway idle when warmed up) but I've since replaced my crankcase seals under the magneto & clutch cover, it runs better now. They didn't leak oil or look bad, but I don't have a microscope to see if it was a micro-tear. Now I have to track down a short in my tail light. (Sometimes it works, sometimes it flickers or won't work at all). I don't wanna get hassled by "The Man" over something trivial.
It's been months since I tried the intake hose adaptation & so far so good. I did have to use a bit of grease to shove the intake into the carb "hose". It is a tight fit. If it has ingested any rubber, it hasn't 'complained' or given me problems. I did it last fall, but I haven't ridden it much since then, I wanted to fix the air leak before giving it much use, I don't wanna melt a piston. Money has been tight over the winter and what spare cash I've had on hand was spent on other things like bills, food, etc. Now that it's springtime & money is flowing a bit more, I'm back to getting my bike running decent.
Rusty, I understand your concern about the fuel vapor issue, seeing how the hose was not designed to carry fuel, but hot coolant. So far I have not had any problems with it, but then again, it's been maybe a dozen miles clocked on it since then, so I can't say definitively that it is goof-proof. If the gasoline does eat the rubber, it has to eat through a considerable amount before it can leak, seeing how tiny the original o-ring was compared to the length & thickness of hose I'm currently using now.
Remember, the primary ingredient of automotive coolant is ethylene glycol, which is a derivative of a long chain alcohol molecule. Consider again most times auto coolant is about 180 degrees Fahrenheit. If it can withstand all that, I feel confidant that the tiny amount of rubber exposed to gas vapors is minimal compared to what it was designed for.
By the holy power of Love, Life & Laughter, I commend you to Go Forth & Be Awesome!
Old 04-29-2013, 12:35 PM
T_Raw T_Raw is offline
I rode the bike to work this morning. I haven't been able to check the carb. I wouldn't say it really bogs I guess it just has no pull after it hits about 15 mph. I used some gasket sealer on the o ring in the carb to try and seal the hole up maybe that will help and I will check the spark plug and post my findings when I get home
Old 04-29-2013, 05:55 PM
Okay so I found the problem when I got the motor the bolts that run through the crankcase were not bottomed out so I fixed that. Runs better still not where it was when I first got it. Had it up to 31 the top speed now is 18. It's a grubee skyhawk 66cc engine stock with a CNS carburetor. I did mess with the air enrichment screw but would that cause me to lose that much speed? Any suggestions?
Old 04-29-2013, 10:07 PM
crassius crassius is offline
the bolts that run through the crankcase are important - don't miss the three that are under the clutch
Old 04-29-2013, 11:22 PM
i did not check those but I will. bike ran just not well. I adjusted the float to try and get better rpms at a low speed because it runs better when the gas valve is shut off and now it wont start. lol.
Old 04-29-2013, 11:53 PM
aussiedan aussiedan is offline
sounds like you have a bad crank seal i had one bike that started to run bad and after replacing most gaskets,trying different carbs,exhausts and coils i replaced both crank seals and it runs perfect again. i think it was the clutch side as there was a small amount of oil seeping out but wasnt sure if it was grease
Old 04-30-2013, 01:17 PM
what exactly are the crank seals
Old 04-30-2013, 02:35 PM
the crankcase is sealed all around its edges by those bolts you mentioned - at the two holes where the ends of the crank stick out of the case, there are two rubber seals to prevent leaking there
Old 04-30-2013, 10:53 PM
JTona23 JTona23 is offline
just wondering how port matching the inlet and exhaust ports of a 2-stroke will further increase engine efficiency
Tags
MotorBicycling.com
