Old 10-01-2008, 09:58 PM
the_edge150's Avatar
the_edge150 the_edge150 is offline
Dealer
Default re: Motorized Bicycle Take a Tip...Leave a Tip
never use a 415 chain on a 41 sprocket, your bike will lock up on you as soon as the chain warms up
Vertigo Motors, No Longer Selling To the Public
Contact at Vertigomotors@gmail.com to suscribe for updates...................live long,live fast,ride to cruise,not to speed,and you will enjoy your china girl to its fullest!
Old 10-28-2008, 01:33 PM
Dave S Dave S is offline
yea Decon my throttle was horrible.I did my throttle, put a set of harley grips on. I used innertube and electical tabe to increase the size. I had to send my engine back cause it had a blown head gasket but when I get it back it should be good. Any idea's for a bike issue I need like a fork lock I have ape hangers and they hit the tank I need to have forks lock so they don't go all the way around. I have pic's but haven't figured out how to post them on here. Any suggestions welcome.
Biker Dave
Old 11-09-2008, 05:45 PM
jacliny's Avatar
jacliny jacliny is offline
i've gleaned so much from this forum its time i can hopefully give something back! It seems that every bike i mount an engine on to needs to have the carb moved, so the first one i spent hours on welding up a steel manifold. it worked well but took to much time to make it look presentable. However you can get a copper street 45 deg elbow in 5/8". It seems this size (5/8)is used for central air conditioning systems and any good supply house will have them. the stock clamps work fine its a perfect fit on both ends and if you need to make it longer just solder on another piece (or silver solder if your worried about temp) i took some temp readings of the manifold after riding hard for about 10 mins and could not get it over 100 degs so for me regular plumbing solder works just fine. if i can get my camera up ill post a pic. Hope this helps someone out. Thanks guys your great, Joe
Old 11-09-2008, 05:51 PM
jacliny's Avatar
the other thing i failed to mention was instead of heating and bending exhaust pipes to clear the frame, try cutting a shim using the exhaust manifold as a template, use aluminum flat stock 1/4" thick then after youve drilled the holes and shaped it place it face down on a belt sander and taper it as much as u need to. then reinstall with two gaskets. Joe
Old 11-09-2008, 05:52 PM
jacliny's Avatar
Oh and watch your fingers on the sander!!!!
Old 11-15-2008, 06:16 AM
Mr.2Tcycles Mr.2Tcycles is offline
Lots of parts that we want such as extra gas tanks, fuel system parts, etc can be gotten at go kart sites. I have plastic and metal tanks plus components at www.gokartracing.com, there are others out there too. When stumped for parts I usually go search there.
Old 11-18-2008, 04:42 PM
Large Filipino Large Filipino is offline
I got a great tip here thought I would share.
How to Stud your Tires for the Winter
1) Go To Wal Marts
2) Bring Money.
Old 11-18-2008, 06:13 PM
TexasDav's Avatar
TexasDav TexasDav is offline
I can see I need to make a check list, or build a assemby note book. There is so many things I want to do on my next build from all the ideas here. I know I will forget a step and as in the past have to duplicate so many steps like pulling the motor out over and over.
Old 11-18-2008, 06:28 PM
jacliny's Avatar
found a site that can supply anything we might ever need! Industrial Supply Equipment from MSC Industrial Supply, from threaded rods to you name it, order their catalog, its over fourteen hundred pages of great stuff! and shipping is fast!
Old 11-18-2008, 06:51 PM
Saddletramp1200's Avatar
Saddletramp1200 Saddletramp1200 is offline
Custom MB Buiilder
Way to go dude! That is what this forum is all about, Helping each other, Yea! Rode about 55 miles today. Just puttin', the world goes by so fast in a car.
Only Bikers know why dogs love to stick their heads out of car windows,
Tags
MotorBicycling.com
