Old 08-22-2008, 09:25 PM
lilhudi lilhudi is offline
Default re: Motorized Bicycle Take a Tip...Leave a Tip
if your rear chain tentioner slips
find a couple bolts and lousen the mount. stick the bolts in the gaps around the bar
tighten the bolt back and it wont move it a bit
Old 09-18-2008, 07:20 PM
redrockrider redrockrider is offline
Thanks for the tip.
Exhaust refinement: I removed muffler and then removed end of muffler. Looking at the little holes in the plate inside the muffler, I opened them up with about a 3/8" drill bit and then drilled 2 more in an open area next to them. Then I cut off the small pipe so that it would still stick through the plate by about a 1/4". By the way, when I took the muffler apart, the small stinger pipe was half closed with metal shavings. I then trimmed the pipe entrance, using my 3000 rpm electric drill and a carbide burr, to better fit the exhaust port (a dremel would work just as well). This all seemed to make the engine breathe a little better. my next change will probably be to trim a crescent shaped notch in the rear of the piston skirt, so that the intake port opens completely
Old 09-21-2008, 09:10 PM
europorsche914's Avatar
europorsche914 europorsche914 is offline
You can also make a head gasket out of aluminum sheet metal available from tractor supply for $6 (same cost as 1 replacement from ebay). The sheet is large enough to make like 8 gaskets and is the same material and thickness as the original. This way you retain your piston to head clearance from the factory and can make many more gaskets in the future from the same sheet...
Old 09-24-2008, 08:53 PM
bridgidpnh's Avatar
bridgidpnh bridgidpnh is offline
I had my exhaust gasket blow out on me at 400 miles, so I bought a small piece of thick sheet copper and made the replacement out of that and annealed it (that makes it soft again so it will conform to the joint) with a pocket torch before installing it
Old 09-24-2008, 09:44 PM
the_edge150's Avatar
the_edge150 the_edge150 is offline
Dealer
here is a tip, don't go over speed bumps with solid innertubes at 35 MPH . OUCH!!!!!!!!!!!!!
Vertigo Motors, No Longer Selling To the Public
Contact at Vertigomotors@gmail.com to suscribe for updates...................live long,live fast,ride to cruise,not to speed,and you will enjoy your china girl to its fullest!
Old 09-24-2008, 09:51 PM
Pablo's Avatar
Pablo Pablo is offline
Did it leave a mark?
Old 09-24-2008, 10:01 PM
Dealer
it bent the front rim
Old 09-26-2008, 11:58 AM
2door's Avatar
2door 2door is offline
Oily exhaust and brakes don't mix. I posted a question about this elsewhere in this forum but didn't get a reply. The mufflers on these little 2 cycles are all about the same so I know I'm not the only one to experience oil from the exhaust getting on the rear rim and reducing the friction of the brake pads. Even after break-in when we reduce the oil percentage they're still 2 cycle motors and will have oil in the exhaust. Originally I had considered making an extension to the exhaust stinger on the outlet of my muffler that would run along the chain stay and exit well to the rear to get the exhaust away from the rim but I solved the problem with a simpler solution that only took minutes to do.
I used a copper plumbing fitting correctly refered to as a 45 degree street L. I cut two slits in the unswedged end of the fitting, much like your carburator has on the manifold side, and used a standard stainless steel screw type clamp to secure the fitting to my muffler. Before tightening the clamp I turned the fitting so the exhaust was routed out and away from the rear rim. Before this simple mod I was cleaning my rim and brake pads after every ride with brake-wash (solvent) but now after riding my bike a week the rim is dry and oil free. The cost was nothing because I had the parts laying around but if you buy them the cost should be under $2.00. The attached pictures show the process you'll need to do. I'm sure the old hands here will find this very elementry but to newbies, like me, it might be something that could save them some grief. Plus it's a sure safety issue.
For those unfamiliar with plumbing fittings the first photo is a comparison between a street L and a standard L. One end of a street L is not swedged.
The second pic is of cutting the slit in the unswedged end after measuring the length of your exhaust outlet pipe. Don't make the slit deeper than the pipe is long or you'll have a leak. I used a Dremel tool with a cutoff wheel but a hacksaw will work too. The slit ideally should have a slight taper to it. Wider at the open end so it can be compressed to fit the outside diameter of the exhaust pipe of your muffler.
The remaining photos show the parts and the final installation.
Good luck and enjoy your dry brakes.
Old 09-26-2008, 02:01 PM
Venice Motor Bikes's Avatar
Don't eat yellow snow!
Follow VMB on facebook>>> facebook.com/VeniceMotorBikes
Follow VMB on Instagram>>> instagram.com/venicemotorbikes
Old 10-01-2008, 09:16 PM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
Never kiss a girl with a high fever (from my dad when I left home)
Tags
MotorBicycling.com
