Old 09-16-2016, 05:27 PM
mogollonmonster's Avatar
mogollonmonster mogollonmonster is offline
Default Re: Motorized Bicycle Take a Tip...Leave a Tip
Here's my tip. While there is no such thing as too bright a headlight, do not forget your taillight! Those are important. A brake light can also be as simple as a second light in the same housing, on a momentary switch. Make sure folks from behind can see you, or they might be the ones to run you over.
Old 03-09-2017, 06:17 AM
LordJaidous LordJaidous is offline
My experience thus far;
1. Carb jet fell into reservoir bowl, bike wouldn't run without choke. Open that, tighten it down
2. Pinion gear (small gear next to big gear) flat head bolt came loose and chewed up woodruff key, installed a crush washer and used impact drill to mount it
3. Throttle got stuck wide open because bracket to intake was too tight, loosened that and all is well
4. Bolts on the head, one was missing a washer so added that and tightened back down
That's all so far, it's always something, I'm sure I'll be posting again soon.
Shout out to all the people on here, I really appreciate all your help
Old 04-14-2017, 09:07 AM
mikadonovan's Avatar
mikadonovan mikadonovan is offline
There are a lot of pages to this thread, so apologies if this has been covered. I have had too many failures with the chain tensioner, and one of them happened at high speed and locked my rear wheel up resulting in a long skid and instant increase in blood pressure. Fortunately I stayed upright and didn't crash and burn. I built this to ride safely and not die due to an equipment malfunction. I bought an extra master and half link and adjusted the chain length that way allowing me to completely remove the tensioner. I have had no problems at all with this set up. The tensioner that comes with the kit is worthless, and a spring loaded tensioner was not much better. Do yourself a solid and don't use one at all, just add or remove links until it is tensioned properly.
Old 04-14-2017, 11:45 AM
crassius's Avatar
crassius crassius is offline
one can also add 1/4in spacers to rear motor mount, but I'm satisfied with the standard tensioner
Sometimes I sets and thinks, sometimes I jes sets.
Old 04-14-2017, 01:48 PM
rager.eric@yahoo.com rager.eric@yahoo.com is offline
chain tensioner!!!
what i did eventually was get a bar aprox 20" length. drill holes and slot to match tensioner. bolt to tensioner and secure to bar just under seat(drill hole and put another
nut and bolts for further adjustments under seat).
Old 05-16-2017, 12:40 AM
MEASURE TWICE MEASURE TWICE is offline
Any clever way of emptying a gas tank that has an inlet a bit above the bottom of the tank.
I used a siphon hose and stuck in in the tank that did fairly well and then on my motor bike the fuel can be emptied from the out let. It is just moist then an can air out.
I have a generator that I did the same and there still is gas in there and not emptying. I might remove the fuel filter that is at the outside of the tank outlet to see if it will drain the rest. I added the fuel filter when the carb had problems and I changed it. It might need more pressure to empty. I did remove the gas cap as the gen is like a automobile gas tank and is non-vent gas cap.
I put the gen up on blocks to tilt it so it would drain best. With my motor bike taking the fuel tank off to thoroughly empty the fuel and dry it is quite easy. I'm not sure it will be as easy with this generator. I saw the out let tube where I could possibly unscrew it and then that would be a way. I am just afraid of not having some part that needs replacement if I take it apart and needs a new part afterwards to replace the valve.
Anyway will be checking on Smokstack to see what people have done an works.
Old 05-16-2017, 10:52 AM
crassius's Avatar
I sometimes use an old turkey baster.
Tags
MotorBicycling.com
