Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > Norm's 2 stroke repair center
Norm's 2 stroke repair center Having problems with you 2 stroke motorized bicycle engine? Just ask Norm. he loves to tinker and troubleshoot engines.
Old 09-26-2009, 10:03 PM
mpnavarro1 mpnavarro1 is offline
Unhappy can get the motor to stay on
the promble is that i can get the bike to stay on.the the throlle stay stuck on high rpm.when i start the bike i could only start on half opend chock .i already got a new carb,a new throlle cable,but it seem that i have the same promble.can someone help pleace.
Old 09-26-2009, 10:43 PM
mechanickid's Avatar
mechanickid mechanickid is offline
Default Re: can get the motor to stay on
so no mater where the throttle slide is positioned it runs at a high rpm?
or does the slide only stay half way open?
its only too fast if you cant stay on!
Old 09-27-2009, 02:32 PM
i acually bought a whole new engine for this little promble.the throttle dont come back to the normal positon.i thought it would be a petty fast fix if would just buy them new. but i can still get it runin jet.i was going to lube the throttle cable to see if that would work.or i think the throttle cable is to big it shouldnt be be big.i bought this engine from that dax.this is my second engine i have bought from him.i still have the new engine put away.the one that i am fix is the frist one it always ran good on till that little promble.or do u think it is the engine.
Old 11-06-2009, 03:05 PM
doubledice's Avatar
doubledice doubledice is offline
if im understanding you correct the throttle just stays high right?
Did you check the spring in the carb?
Old 11-06-2009, 03:10 PM
bairdco's Avatar
bairdco bairdco is offline
a guy who makes cool bikes
where are you at in california? i don't normally make house calls, but if you're close, i could cruise by.
throttle cables are pretty much a standard size throughout the industry. i doubt yours is any different.
sounds like a simple problem of adjustment, but we need more info.
Old 11-07-2009, 10:53 AM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
take off the air cleaner look at the throttle slide it should go all the way closed if not you might have the throttle slide in wrong the split on the side of the slide aligns with a little tit inside the carb
this keeps the slide from rotating in the card.
you need to check it. if this don't help let me know.
norms-iron-works.tripod.com
