Old 08-12-2009, 10:03 PM
Kevron99's Avatar
Kevron99 Kevron99 is offline
Default Do I really need a 36 spoke wheel?
I am a newbie....does it really require a 36 spoke wheel to install a sproket?
Old 08-12-2009, 10:38 PM
Retmachinist's Avatar
Default Re: Do I really need a 36 spoke wheel?
If you are using the kit supplied sprocket adaptor it is easier if you have a 36 spoke wheel since you will be using a nine hole pattern.
But no, you don't have to use a 36 spoke wheel if you are going to use an alternative adaptor such as the ones I make or the ones Jim (Manic Mechanic) supplies.
John
Old 08-13-2009, 06:59 AM
Bikeguy Joe's Avatar
I have a couple of 5 hole sprockets that fit other wheels and don't really work too well with the standard spoke pattern. Maybe that would help you out.
How many spokes does your wheel have?
