Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > Motorized Bicycle Trouble Shooting
Motorized Bicycle Trouble Shooting Use this area to post problems that may arise, if you could use some help in figuring out what is wrong with your engine and what needs to be done to achieve top performance.
Can I shim a spark plug for fit?
Old 08-15-2013, 02:54 PM
runkmaster's Avatar
runkmaster runkmaster is offline
Default Can I shim a spark plug for fit?
I just purchased a NGK Iridium BPR7HIX spark plug for my first build. It's a two stroke engine. I have the cheapo chinese oem plug with the washer. Can I use another washer to shim for fit? By adding the extra washer, it appears the plug will be the right size. Thoughts?
Old 08-15-2013, 03:18 PM
2door's Avatar
2door 2door is offline
Default Re: Can I shim a spark plug for fit?
Not following you. When you say "will the plug be the right size" are you talking about length of the electrode, or 'reach' as it is called. Just install your new plug as usual, slowly rotate the crankshaft through one revolution and check that you have no piston to spark plug interference. You shouldn't have any with that plug.
The Following User Says Thank You to 2door For This Useful Post:
Old 08-15-2013, 03:21 PM
xseler's Avatar
xseler xseler is offline
^^^ This.^^^
Two washers on the plug will cause it to leak compression. Even though it's got a longer nose, the plug should work just fine --- many of us have 'upgraded' to this plug.
Good luck!!
You're never lost until you run outa gas.
The Following User Says Thank You to xseler For This Useful Post:
Old 08-15-2013, 03:36 PM
runkmaster's Avatar
I tried this and the piston hit the plug.
Old 08-15-2013, 03:45 PM
2door's Avatar
Now you have a problem. Not a common one but one you can fix.
Take that high priced plug back to the store and ask to compare it with a standard B6HS NGK plug. I'm not well versed on the iridium plugs or their sizes and heat range except what I've read about them and there really is no advantage to them over regular plugs except they will last a long time. That doesn't equate to better performance or a "hotter spark", it just means deposits don't build or stick to them as readily as other plugs.
Check the thread length between the two plugs and the reach of the electrode below the threads. My guess is you'll find the standard B6-HS plug will look different, shorter. If so, buy it and your interference problem will be solved, me thinks.
Old 08-15-2013, 04:24 PM
runkmaster's Avatar
Thanks boss this really helps!
Old 08-15-2013, 07:00 PM
timboellner's Avatar
timboellner timboellner is offline
Spark plugs with an "R" in the prefix before the number are resistor plugs.
With these weak sparked ignitions I personally would'nt use a resistor type plug, or a resistor type plug wire. Others may not agree.
TiM
Old 08-15-2013, 08:08 PM
2door's Avatar
TiM
I agree and the reason why I always say that the stock (kit supplied) spark plug wire is better than what you'll get at most auto parts stores today which will be resistance wire. The common myth says to replace the wire and the plug boot. I maintain that the boot should be replaced but the wire, being metallic core (conductor) is better than the resistance wire. Do what you feel is best but if you doubt me check the wires with a good ohm meter and make your own decision based on the resistance you'll read.
Old 08-15-2013, 09:12 PM
dodge dude94's Avatar
dodge dude94 dodge dude94 is offline
FWIW, I run a BPR7HIX and there was a huge difference in power delivery. Just my experience.
If it's hitting, you've got some pretty good compression, so like 2door said, get a B6HS.
2 WHEELS: '11 Huffy Good Vibrations, '11 Skyhawk GT5, 44t, CNSV2, NGK BPR7HIX, Bosch wire, shutupexhaust, 26x1.75kevlar tires, Tektro C230's, new stupid Bell chain
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
MotorBicycling.com
