Hey Guys
I want to modify my motorized bike to have a push button to start instead of pedaling. What is the best way to modify the stock ignition system to make this possible?
A 12v DeWalt drill will turn it, set on forward (screw-in) it turns the motor the correct direction (and tightens the magneto bolt; +1 to reliability!) A 12v minigen will charge the battery for the drill motor while the engine runs. It'll be a very slow charge, but it should be enough. A pull start could be adapted to encase the drill motor, and then the engine will release the drill motor when it starts. my roommate and I have been planning this for some time but havent had the money to attempt it yet.
I used to use an 18V B&D drill from walmart to start my engines for testing before they went on bikes, it takes a long time because the B&D Drill is slow, DeWalt are MUCH more expensive, higher torque and higher speed, (my friends dad used them to turn over dirtbike engines), and will get the job done.
