New motor, 66cc sky hawk with NT carb. Recently got it started. Runs alright at WOT but jerky bottom end. Plus I have no idle... I could be riding and pull in the clutch and after the engines RPMs go down it cuts off... I was thinking an air leak... I tried the screw in every position, sealed between the carb and the intake and around the gasket also. Same issue.
Where else might air come from? I thought an air leak was my problem but now not so sure.
Iv looked around the threads and searched and can't find an answer to my issues... (then again, sometimes I can't find my phone while on it)
This thing is really testing my brain...
I really did not want to ask such a noobish question like this but hey, sh!+ happens...
If it's not idling then it must not be getting enough or too much of something right? I know fuel flows through the line, I sealed what I could..
I know that there is a needle connected to the throttle that has an effect on things and that is on the middle notch. And I removed the jet and could see straight through it.. Idk what the issue is...
It's prolly really simple too.....
