Okay here is what I know. From experience I can run a lead acid battery of 7ah to power my 36volt bike. Not for a great distance but it will run it without over heating and at pretty much full speed till it runs dry.
I know I can build a nimh battery pack of the same size and it will will run the bike much slower and will overheat very quickly. Something about the c factor I'm told. I think you would need a 25ah build to run a 25amp motor at full power.
Lithium I expect has a better usage in some ways. It will run a bike at full speed with half the ah rating of your max amp usage. Ie a 25amp motor would need a 15ah battery pack. But I don't think you get max power out of say a ten ah battery pack on a 25amp drain. At least that is my understanding.
Here is what I can't find out on the net, probably because I don't know enough to interpret the answers that are out there. Is the discharge rate for alkaline batteries the same as lead acid. or more like the Nimh pack I built.
Before you tell me I'm nuts to consider anything other than Lithium, I have been told that hundreds of time. I am an experimenter. Someone has to try it first to find out what it's like, even if it is crap like the nimh packs I built.
So if, you are nuts is all you can add to the discussion please don't bother.
