I have run into a problem and hopefully someone here can give me some ideas.
I had to make a modification be able to mount the carb (as seen in the pictures). I am wondering if this is causing my problem.
Fully choked it will idle (if a bit high) but if you give it any gas it will flood out. With the choke al the way down it will not idle, but the throttle is responsive and it runs great.
I have tried lots of variations of adjusting the idle and the choke with limited success.
I thought my modifications were letting in air hence the tape around the joints, but no change.
Is there anything you can think of that will let it idle AND drive? Do you have any ideas on any variations on how to mount the carb?
