I I have an 80 cc 2 stroke that is more or less my main transportation. That the clutch has gotten slow on. It will disengage quickly but takes several seckonds to engage and it dose so slowly. Please help
I'm not quite understanding your problem.
Are you saying the clutch slips? Does the engine rev high then seem to grab after you have released the handlebar lever?
When i use the handle bar lever to pedel my bike so i can get it started and release it the cluch is slow to enge and it just kind of boggs me down rather then turning the moter quickly
How fast are you pedaling? You need to be doing about 10MPH before releasing the clutch lever.
Are you using a high compression cylinder head? Your symptom sounds as if the clutch is engaging but not spinning the engine. This is from the clutch slipping. Either the clutch cable is too tight or the clutch needs to be adjusted.
Here's a good tutorial for adjusting the clutch and cable. http://motorbicycling.com/showthread.php?t=22729
