new ring on my piston, do i need to break in?
motorized kodiak
105
australia
hey every one i got new rings on my piston and i just wanted to know if i have to run a 16:1 mixture again to break them in. also do i need to take it easy on it and not push it too hard?, i only changed the rings not the piston. thanks
Kioshk
1,152
10
Connecticut
Nah...I believe the break-in mix is more for a brand new setup. I never have gone into break-in mode after top-end replacement. You WILL however notice a power increase as time goes by as the new ring seats in the cylinder. ALSO: go 20:1 when you DO break-in; 16:1 is too much oil.
maniac57
Oct 8, 2011
4,484
22
memphis Tn
Once the engine is broken in the first time, I don't bother adjusting oil ratio again when rebuilding unless the entire top end is replaced. I just stick with my normal 40:1.
mrfubs
306
12
michigan
not really a break in just ride as you normaly would, just dont run really rich or the rings wont seat as good as they could
