Micargi puma is almost finished. I was using a spring chain tensioner but the chain kept skipping a tooth at the drive sprocket - jammed up at 20mph. luckily i just skidded to a stop. then it did it again 2 more times.
I have two of the standard chain "tensioner' wheels that I am using as guides to keep the chain located between the wheel and the frame. the top wheel in the picture does that. the bottom guide keeps the chain under the frame. I was using the spring chain tensioner, but I'm re-doing it to omit the spring chain tensioner. obviously I'm not using the chain wheels exactly how they are designed to be used.
do you think the top stationary chain guide might be the problem instead of the spring tensioner ? does the top chain need to be a direct pull straight from the rear sprocket ?
I got rid of the spring chain tensioner but haven't tried it on the road yet. check out the pics
