I altered a few things to make the MB run better & faster.
1- Removed most of the engine shroud for cooling (just left 2 pieces that cover moving parts)
2- Drilled large holes in air filter cover for breathing
3- Removed the muffler cover for cooling
4- Lowered the fork sliders 2" in the triple clamps for handling
5- Strengthened the engine mount & now have the engine additionally supported by the previous gas tank bolt holes.
6- Replaced the fuel line with thicker stronger tubing (previous line was being pinched @ the grommet & would bog the engine at WOT.
7- Removed the gas cap rubber plug doohicky to allow better air/fuel flow.
8- Replaced MTB rear cassette with a new Road cassette
9- Installed new chain & saddle
10- Experimented with different pulley sizing but stuck with original 1.5" engine v-belt pulley
11- Redrilled motor mount to pull the engine back a few inches & more perpendicular with the road (new pics posted)
12- Drilled & bolted together the front drive rim to the rim pulley instead of just being JB Welded (Glued) for added security
